using different brand tires
Old Apr 20, 2018 | 03:43 PM
tph88's Avatar
Default using different brand tires
I have a CX-5 2016.5 GT. One of my tires had a hole in the sidewall. So I need 1 new tire (other 3 are still almost new, barely any wear, this was confirmed by the guy at the tire shop). However the one tire I need is currently on backorder with Toyo.
I am trying find out if it ok to replace just 2 tires (on the same axle) with another brand / model of tire that is the same size p225/55r19 and leave the current tires I have (still perfectly good) on the other axle. There is not enough tread loss on the current tires to be noticeable (verified by tire shop). I cannot afford to buy 4 new tires at this time, but could swing 2.
So it would have 4 new tires of the same size, just 2 different brands.
Any thoughts?
Old Apr 20, 2018 | 06:43 PM
paris1's Avatar
Why different brands? Is it not possible to get something similar in a Toyo? There’s nothing (terribly) wrong with mixing tires on different axles, but I’d try to get as close as possible.
Old Apr 20, 2018 | 07:46 PM
tph88's Avatar
yes I am fine with that if is possible. Sorry I should have suggested just a different model and/or brand. Thank you for the feedback and suggestion!
Old Apr 20, 2018 | 08:27 PM
mazdaCPA's Avatar
Have you tried TireRack or other internet sources?
Old Apr 20, 2018 | 08:38 PM
tph88's Avatar
For the one I need? Yes I have tried everywhere, even had a tire dealer call Toyo to find out they are backordered. Some online places list them as available, but when you try to order they then tell you actually can't and your order will be cancelled. Toyo A23 255/55r19. But looks like there is a Toyo a36 in that size available, so I will look into that from my local tireshop on Monday.
Thanks!
Old Apr 20, 2018 | 08:54 PM
shipo's Avatar
Thanks!
The trick to employ if your vehicle has rare skins on it is to buy a new set and then auction off the other the other two; you'll typically cover the cost of the new set, and sometimes even make a few bucks.
Old Apr 21, 2018 | 11:05 AM
paris1's Avatar
Thanks!
OK, I'm a little confused here. Your car takes a 225/55 r19 A23 Toyo as stated in your original post. I just went to TireRack and they appear to have stock on that size. I got almost all the way through the ordering process and there were no red flags raised stating they were on back order or whatever.
Old Apr 21, 2018 | 02:53 PM
tph88's Avatar
When I go to TireRack it tells me it is back ordered right on the tire information page. I actually ordered some from TiresDirect, went through the full process of the order, then an hour or so later received an email saying it was cancelled.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgsAAAC+CAIAAAA 0pdt2AAAgAElEQVR4nO2d+1NT577/1z+Q35hZs8bJZBhH3AzTqLOhfHGq1tt2sHtXuqt723o5p3RP4/lu6RHn0K9xQ822USo0u5Q0AVMUS2OBE1qioGzuIhcREDRc5KpS NVGH6DknMPNw2vr5/rDWStZaWQkBQaJ+XvP8AOv6rJXk816fy7MeChAEQZDnTnd393M 4yKMAhHh86pl7iCDIK42nv/TwthVRSgVDK5ZGx+3RVw0SAHsysy7bAfCk/IOlkb8/NSK7a7mGTjA4nr0LZLzBrNkSuZRWMHRE1Io3Uwu7XM9+1AUGFQ JBkJccd90nq5WROwx1w24CQNzDdYZ3N+haiVchgjI/CuEofDtGuSql9NoDDwBMPugqTVm70+p81sMuNKgQCIK83HTq4x Trs64T/zXPqhAOwzqFxh5CF9wle5XKD8vC32eQggqBIMhLTWvGKnqH1S2 3yqsQjuz1dLIdAIAMlqUkRtMMrVga/WZq2RDxKoSnK2sTvTqthjfzDsM6BUMrGFrBHsTVlL0nfomKVjC RMe98dnFcoEhu6w5mZUarfP9cTYY/JyyLYGjF0t9u/ezCXcL1J+Gg/oO4SAUTGZNqH6g+FL+UVqiWbcntIXzPD5kPvRGlVDDKJQm7TnY TALhb+R9vxkQqGDoiKv7PFu+W9Nua/VEqOsHgEHVyj+HyjJKFCoEgyEuNPZnhrL/cKrFCuCv3xSjX6BruEgDPWF2h3cH5EE2XdZvozTqJSRX4EI6cz crIvYUDHgAy3qjbFBGTVk982yUEclYcX61RRe8s7J8EIOMNGZu VkWl1BBzZ62lF/N8ue4B0ZyUwdMTmrC4PTF7Yr2S2nbzDXZT4dPsvuIGMD4+4CQB MjhXsUMUd7eC2VH5YepcAwMjJpMg1WW2PCQBxX8naRCdZRoPfP FQIBEFeambjQ9g1ilW6NvFG5RpaGRMdwaw81CQNVPkUwmFI4Gw 3AACQsj2Mcl8l/29gH8JhWKdIsoz79ktWqPZfYH0ILrRlT2boPWVE3GF7MvNGZrd vN/Z0k52FHySuWKJiPRtWF4UCaU/mnB5v05QHv3kvokIInDta5OUBABlvNH/E+lkK1bKoxI/MDZyz5ypLVopl3GV9P0K1KWemHREEeZEh9WnRM+UhBAqxPK1ev FG5hlYm5ZZmbYqI0ZQH8iGCKwSMnEySz0OEqBACEx9EITqOxtM Jx5ofegRXJNq9cp8q6mDtzLfMx4uoEDzCmwgAAKQne7MyYvX+0 q4HkwDgGWst3L9KFbmBi9yNnExSRuwtecxtXHcwhn5N10pm3hF BkBcZl33fSkkt0874FPvjGaNMeSWdvkz1yMkkZaTGLrTyDsM6x VvmUSCEBI0yAZDurzYsFdcypa7dYHAEiTLNpBD+UabWjFX0xi/7J4HcbdCtUfkrBKlPi47YnHXFTQA8t2oM2faZiqleIoUg9WnRC vGnAgAuuyaSYeNxQFp1rzFxGa0EAEbNWxXLNeXukHZEEOTFRjI e4p1DNuF4CEmmehObN5ZkqgFc9uQYZaJFMGzCYdoSpVSoEk0Do kx1ZOIB26D08VI6HkJjZrMagkw1d0YISSFkMtWu6kNvRCkVqmV vHDYfkvEhAMigLXUj38mPCjs9M9y3l0ghKvep6I1m/zEvjuz1tDKtDgA4CU2yjLrtycuVO7hi5FB2RBAECR9CqtOdB14 ehXAYEgLkgso1tC/S57LuUEWt2RynWM/vGeKOCIIg4QIqhIB5UIjNX9307mZYp+BjTbPaEUEQ5NXi5VGI0 INFdo24xgujTAiCIHK8RArBJpxTa8SpF5mEs1QhQt4RQRDkleI lUoiQi1alCoHVrgiCIHL09vZOTk4+yxGmpqZ6e3uDb/OcFAJCG/jmrxAh7oggCPJKcf/+/aGhoampqbntPjU1NTIycv/+/eCbLYxCIAiCIAvJ06dPnU5nb29v95zo7e29f//+06dPg58FFQJBEASRBxUCQRAEkQcVAkEQBJEHFQJBEASRBxUCQ RAEkQcVAkEQBJEHFQJBEASRZ4EVouNoPC2ddU6lKQ8y4I24b5w 3pO3aEs0OkWNoxdLo6DXb/mqoGAj0vnTPWOt/Gv76zhu+XRjlkpVvbP3LZ4UtY8805hBBEORVZmEVokP/mnRSUlrBKJPtshLhGSg9EL/Uf3u+LU082iSZd8l52bArJsguDE2vO1TjP8EggiAIMiMLqhCd+ jhZq+2bcNTHwLc7o4MYet7/2JTdLVQXUp8Wwl7xujZ8TQeCIMhsWUiFaM1YFcjQ7y5xSzYmbT p5OZGqy45C0cRBrrI9y2fea4dVej4EQRBkBhZQIVp1vwlospU7/SQCXNYdqpltvYJ5X2LtRy3blsRt+ySv7tpPbgIAQB63HUsQ7yV 9jSCCIAgyIwunEPVpUcEM/S6rX6CJi0pFrPz9J4UtI24CAJNjtRmbleJ9Z57hb7JTqhCJljs hXhGCIAjCsWAKUXdQFPxRJiZtDe4KAAC4K/WfXbgrzhk4DOvEO27KGQhwTrtGXo1iNOWYrEYQBJktC6QQpDpV KdGDpqy4ueQGSE2q2BdZpWsLtK2cQtDrDl3E6SQQBEHmwMIohJ 9ZT7KMS70KduEMuOyayNAzCrI+hGrFHy04IR2CIMjsWRCFINUf L/c366RcI8kobDsZLDtAhqy7JfIQsdlwPYixDxRlYqL3VWItE4Ig yCxZCIXwCzGtzGgFAHhsfV9iuzeaR+SPS8YvpiVESOJFWw1dgY ZVi3d+fKNwZ4xYJNZjMROCIMgsWQCF8PcVAre3zKP+B/B0Zm+NFG+pjPrQOhTIe3A5/fPQbbqVs/FXEARBED/mXyGIPTmkYQ1s2yrxIsigdc9KscCoVuwp7A/8eiVHzubINbomsUj4JUJCqJFFEARBRMy7Qjwu2R0RqjxIMs/k7oW0VRJ1iXnX3BkstDRq2RbB1Sx9lH2+66EHADwDpfulx2GSb ZitRhAEmRXzrRDukr0hh5jEGQLH6XcjQ92LdwhGLImh+Styb4J CEARBgjLPCuEu2TmLEBPb4o52AMhkDmZWiNajvw3JX8ERcwiCI HNgfhXCv1rJ7+Hdkb1easFf03fI7juzDwGeLvOMb/8+YBvEABOCIMjsmVeFcFt3SQy0zBv6Rs1bpXY8Xt8JAN3SQdch KAQAcDMIpe3aEr1yGe9SKJesfGPrAcN/4gxCCIIgc2beM9UIgiDISwIqBIIgCCIPKgSCIAgiDyoEgiAIIg 8qBIIgCCIPKgSCIAgiDyrELHF1FFX2Oxe7FwiCIM8BVIjZcbW4 INZ8eWKxu4EgCPIcWCCFmOprrDpgsCSkG9Vaozoj/w8554quOV/4oc3uy/vSC7J62H+m71yp0hzPi9Ua1VrzWoPNcoW9wLZUrTHJNizasb8q SWtMrQfS/ONqrWlf9RPxccctBqP6WOVV/v/rtkK11ujXCnP75+Uy/rvcYlZnWAtl3rz+DPRUbtEatxT3iZcK7gZ/E+SY6qv58U86s1prVKfnJeacsw1OzWvnEASZCwugEOTW9+Z8dc ZpbU2/ywMA4HnYbzt9+vUjNvsLPtGb0IEgreVrtfn7KocmCIDnp5rioo Ts6usAwRUCoCvjiFHqhYzVvqc1vmeXmZP1uq1w/oRhQZmuPp2n1hrVR36sFj0IhKQQQ+etselnMlt+8gAQ91BRvmV DQTs6agiy6My7Qkx3lxaq08/kOqYlK5yuUA8aprjbUo94HQioPZOn1trsvtXThLOMwRUCrhYXq LXF3wvE8rqtUK0tsozJnPOFUQj35X3pxve+O/ee1EMKRSHuncoxqk9UXfct8d5MBEEWk/lWCPflfenG1ac7Av7A621qbV7K2XPvfmpS6ytaAAAeNdltbIQh 9tOCvUUtN/mdne1VmmNmNk71p9Ps8kdNtuLfZRjVWuPrum+1tbcIt2XtAUP+ 63yM4ofhaQA2pJN3uNmnVS1nLer0klK330mL2++QQN3juG4rjD Vd8uao+344o9YWHG33D4bMoBBsNGbP+XveI2UdM6pNl2QfmWUV QvZi+Y19oiX4ty1Va1ydX6HLzovVWjI7hauGc08Y1dkVp4q+XZ thVGvNvzPVd/P3n9y9lmsqSEhnw2g//tAU0AmYuFisTi8pdd87lWNUG2qHZO9GYB+issCkTi8uuit9qgA AMtyiy/H2wVbUw97wcXuR9Q/eqJSpip9Bavpm7Y/vfmpiP1aNrccpdxBLO//9rreptaZUWz0bLYz99Iyu+QV/jkGQeWW+FeJSWWzAWDMAsL9Jo/rEuXrOHDypPG2JTT+TecVJADy3rmRkmmK5cE1XxhFjUnG/B8BzqzOrqGEIAFrLV2sLs3umAKZGWyp1leMAMHHpxw3ppu1nr9 0hAJ6fzp85FZt+xtQPrPH1hXRIx+EjrHpN157JV+tKivqeEADP YOM+nXEtG9aQdo/H3ZZ6pCCzU7DQ1ZaqM6q15m2Wqoq+JwJFnEkh2KyD14z2VG6Ry Uxw+CtE4IudQSHU2sKjXKbETyG0pu2ljgkCnp6q7el8LsHdnqY zxmaWn781BTB950rF9gxTgA933GLg7vNEdUms1udphagQxFG1P d2oTre8X9TYfEsgumP1e9JN2892jnoAiLP+7Bn+YqdbahubR58 QAHL3Wma2KTanfggAxuv3aPNSapwEpif6GrUlXQQA+mt3ZhjXm hv7PADkSav97FptftqlJwD8x62z2W5NAXH+YMnnHyAQBAGYf4W ot80QFam3qbVGzUXeIPZXJWmNH1T6zkc6K7ZoTan10wDtaenGL d9dmxD6I5fKYrUFR68ILfJw7gmjOrfRV4FKbmQeM8Za2gjAkL3 I+5snzT+uZo3XeP0eYR/YR2Ct9dS4X/d4huxFnA0S4uovOn0mId2o1poSss9d4ERlRoWAIXuRN6zUctai TrfZA/hcfgoR7GJnUAiBmyJViCPltdyae6dyjOrs6j6A2+etaq3laLtP FIfsRWpZE99TucXrq/lkGKR3I1imGsjw1SzTN69rWT+mtsMDwIbyRJ7cjUy9cfWZLsm+ t89bucDdUPV2rUlT8ZNgWsJpu8Wk1p9r8t3hR9+bTFxQq96mFv pzreWrtaa0S/I9RJBXkMXxIbwbTFws9lOUtlStcePZGwDT3bYzsVzoqfEKa3/JYG62Sa01JRy36ip77xAA9yWNn0W2W4ycZRmrfY8zAU9KzSbuy f1SWWygSiFx9zhIx+Ej+RmtMjEQAADPT82VZVvTjWpdeS2BUBS Claj37OOsnxQkKCdViKAXO4NCWNpAZtVw7glRDsBu4f6tLDCJE y0Ajqo/yHy409WnhXZ8uvp0nuBJXFYhWJ+GbaJTEPdQRfHZtVpjbE79EI yZsv0/Ju5CnO21BwzfbPjUJC70emS35LMRyAO2K30eYEVFeO385Rd/7/b7uINqGIK8gixKHsL3I7x93iqrEPxz4vRE35XcU9bfZRjVOpud jTWTJz2NVYdyvnlda1xraXOO1++RNZrcczEvDO7L+9L5p0V5Sy fTPZYhe5E4ti6D82JxrDYvo5Xr/x9KB0WrpWd8Umo2qU9UdTf/uJrbSx6pQgS92PlViO7S0yEphPvyvnQZO86XZoXqQwiYbjlboN ZaT41P/5AvyWDz9FclaY1bLM2d484JIvFcp0Y7Gk+YziSkG2Ozq7pJV8Y RWYXwuYyoEAgSiPlWCPbnLVvLdNdJwO832VO5RRJlaj+3kYvLC wpaxmrfY/ci095lQ/YitdZmZzO9osBLz1G9L/3ABpfSCqy+B1tpJESAv0KQrgydKN3NXU57Z4cglgGt5byt98/WgrPyrDSdUF0Sqy3Ynp0nHAbhj1+UKdjF9v1wRlAlNW23mJ5FI Ujzj6tDiDIN2Ys4a+tDOLwjFIWY7r5y7Y7gw7h93soeUxiOEyE OZpLaUv5f33eGNP+4WluY2/+k1CyNMhXl8t1DhUCQoMy7QgCQwVO5+er0U2mC8RAVxd9vSD9j GvI3wY/slny1NFNd1U0ArpzbkFlm63tCYHriyrkt2nzdFWgosmwtaO5xT wN5Uv9dgVp3rgHAWW9bq5UmbwUS1Zd1zKjWiiTh+g9nYrX5qTV cAX5F8dmdZ2/ICBhbqi/jQNzQHzXGct0Dz63OzGxvgh0mLpWt1fL5VZgabanYns5nwn13q ePwEaNaZoiZCP9MdbCL7ancojXtKR/1wPREV9X2dOOzKATAsCnbJMxU/yXX6udDiGsBeCYuFqu5zEQICnG/8S/pxrW5VTW3pgCmJ/oEhQNstjy7qtU9zToHaSdKvndxV7q9tN8D4BlsTDlqYu/S7cqzG7jjTI1WFMemn/12nEuDSzLVqfWPAFAhEGQGFkAhAOTGVP/ADTmWCeMEqHYlt34osiZylYtnDlwcJKKyRVNCts3Ky0CgAlCWq 8UFalGBDfgP4i26LmcySFeGLi+1Xq7QyDNq83XP8qfTzX0Cl8L XHzYmbu/xe5UTO8RMfhiEl1lVuwpKgc1rDT9+eer0sykEgKe/yHImId2oTs9793TLzfqyWO3pLwUTwAYYIs6FnmLNlydCrGW6e8 1iYcttja/rTmtsPpdCUHHLZheu3iQAMH3zoi3xU5Naa/6dqaqpkncpXD2+4xyznuBLV4NWu6JCIEhAFkghXhKcF4tjZePg ryRXiwuClF0hCPLygQoRDOIeutIrP1Lh5cfVlpb9fVbj0AQBPl Zm2v7D8Iz7IQjy0oAKgQSAOK9Untv7ORsrMyUct+r4EewIgrwi oEIgCIIg8qBCIAiCIPKgQiAIgiDyoEIgCIIg8qBCIAiCIPKgQi AIgiDyoEIgCIIg8qBCIAiCIPKgQiAIgiDyoEIgCIIg8qBCIAiC IPKgQiAIgiDyoEIgCIIg8qBCIAiCIPKgQiAIgiDyoEIgCIIg8q BCIAiCIPKgQswb7rLUPfrzN9w4Dxsij6e/9PC2FVFKBUMrlka/qTE3juOX5RXBkb2eVjA099Gnlg3N4pO3JzP8vlxbl+24cWIdHa ltXLAO86BCzBed+jgFQyvi9Z2L3RMkHHHXfbJaGbnDUDfsJgDE faM0dS29NDGnG0XiVcCRvZ5OMDgAYHKsNDmG+3t2hzCsU2jsC9 C3oCyAQpC7DYY/JyyLYGgFExmZ+JG5YZwAwI3seGZ+RU8gy1xTLlm5JaW0f5LbwH OrxvzXd96IXMpJd9w7h0r7Pb4DeMbqzB9vXRNNM7SCoemYN7Ye Lh0QrAe7RiFVb1bA/friticvpxWMcofVyS4o1/jvSCvWe78X/s8FtILhvjcOwzrpqqXRcXv0VYNE/uC+7w2522D+IJG9IuWShG2f+O6GGDLeaP7ozZhIBUMrVMtWSO4 MABlvMGu2sLcuIipecGcEt12lKffaN4chge+PMrUazZ6ETn2cY n3WddF9IfVp0RFJllFg756mfJH6hiw8PoUA9vc7e1v/kigEqU2LZKJ3Ft54TAA8Y3X6xCWbv5q1XIaEv0JwOvFbfSuBO7 bkaJm1qk3Z7FPbHdvuGJndIzYbvD/jccu2EBVi1LxVwdCKmLR6bt87J5OCKsQdS+KsFILvfI4DILBCu OyaSL+9IjV2l7S/znKN/82JTrZz8gYue7L/zYnRlLsEF8vQCibqY14LBH2OOlg7L5/vy0Rrxip6h9UtXdydFcdsO1nrE9eE1NSNzFbzCLe+Ux8XsbfkM YwUvBtJv3tq9Dn3Gpk3pD7Ea/oOADJUdoB9SouI2phSNkiAfVZ4Y09KIs3QyWI5kChEuYY7YLmG VuzQ7FupVKw3OMB52bCLjWTScbuym5wAACOnfr808venRmAOzL tC1KdFKURPQ4Qs1PNkIIWgFcz7VjeMWrZFyK2NSKkEAICRk0lK WYHZV8mdoE23MiSFINUfL6cVDL3R+8uG1oxVQRWiVfebOSgEQ0 do7CSQQvDd8GtRyXa3uL+pStnjL9eUuwGA1KRGyZ5dqbE/BgC3dYd3CecuCD4LjLPJYE/2+8Hzy9dlO4Q+hLtkr/I1fQcAALRmrPJpMPIiI5OHILVpkTGa0jEPcLIRfbCWsL54wrFO f9c/mEIsTy4dJwAwatlGb8664iYA5HFb1pql207OSRd8zLtC3MzdpG DiDjV5/NbYkzkLKGPZuR8PGbTxqTw6ZssHhfxtcpg2LKUjUyofiw4oOM5 6gwM8XcfEj7GkNWPru0fPdz30AJDxb3bwG2/+6iZ7tlbdhh36810PJgHIeMHbfGfW5A6wJ/AaYnopq/Px0jAUAAAvRctTa3y/ZW8QKZJeSssEfLzxq6WRNCON8wgUYl22A8DTkLZKeKV+l89+b2 rTeLsfd6jJA2S89EPe0CdZxgUdrk/jl8f/7bIHyHjpHl5aEi13AOoO8v++lt40CeRuaTJ/5G0n7wBrxXhRSa0hohDTHAKsrwBBfIhNOQOiKNPjkt0RrMrWpi lFXyrkxUUUZeIW+T0IJhgc4DAkyMaxgysEv9w/uC33XDIb5j8PwQUoIuM1BnFhj1chBJDWjHiaj8+OnExSRmzW1Y 15AMjdBt0alXJNrgNgrgohOlFPJr8x/4AmXt+dxdu4uKMdfscXPsULwlAAAKTuYIyfZRRYTKF3ssbQQ7j 1cl4CHwETrH3j08bbd/rPei24V95kFMKXNfFTCNX+C4Iu+75GfgoRkVIpzJH4KQTnYAm8 kKiPq4mgw74ICSKA1KdFC/MQ/9NxYsPWLHNqNOdyCfMQpPrj5VEHa0lNapTsdxV5AZFRiJu5myS PbgDwjApxIUWpTKubz44vQKYawNVZmLpxiYpWMMolmw5d5Er6/BXCfSEl2pcYqE1TMiszWn2r23QrFcvT6gOefIYokw9Pp3kHF3a PWJ1W4xeVn+w0v82F3ZWr0qr59S1H4uTDUDtLfEd3Wd+P8MVne Fr+HqOS65hqN7tr69HfykfA9pY8DhplEtxAP4WQlyW2ibKgQY6 v0NiD3livt+eLaCnTisxv8RvssopVHOFx2fetFNQyPaj7JIFWM Osy2S+/w5DAbDWPcDHZNt1KZcrhfctRbl8aZBQCRiyJqujk0rFJtrZNb2 kjz6oQpDYtUrUps81NACbHarMN/jnIWbIgCsHiGWst3L9K5c3fShXCZddEMryXwIWnZjBtYgJmqr2 P6gAw2Wn+40rW0Cujdpq7pDEiT5d5ZxRrzVUr/mgWh//I+NXalhE3AYDJsbPiB22WjqPx8n4JGW+vbxl+TADAc+us9Bkcg Nxtr2sddhMA8IydFT/sB7DgyqgPrYIyaj+FkM8/y91G2US04FCyGW+RQnirexlasTzKe3VC7USkiMdDxL3z8e7NSt 4zdpjeXhbBKDeYBgAAOvSvieQWM9UvOnIKAeBqMvw5jo9gf3bh 7jMrBJv9fkMSqA+rTLUEl/X9CC7mI1YIV9me5XTELqtX4khZsnwhaUDkql1F4X6R9d9T6Ff3 6ek071zBPstHrEwu7Jeqh8u6/4/6imsP2FSSTyG8ftzjkt0RAs9AgNOaspNLgYgUgg9/uaz7dnIpEJFCLE+rFynEyn/5N2++PWpPmVNwCn+FACCDtlS2RDUyct32D97lM+3rpd9NMliWw hbFLo2O3/HR7/k8B/8B+aos6Ji1b2ve4fPqgg+ItWLChkHz2eLpv+b3rQMAgKZDr6Hc ImHAvCuEq6lW9Jxem6aUUQindZdSsTzZJnSBRswbReVAMyLJQ0 i59OkK2UgOv33j4ZWyQSTOUJJuwxrZSJGvNIjrwGu6VrFhJNcN m+RPzQajSE/2ZvlTs8VCokx1d2tGPL9BzP4LPqMhpxCusj0y5UzKRIv0rrrKk mXKmVTeygen7UOZciaueN/7gb0l7jwOg5gPCCGkOhVz1EhYMN8K0XJ4JR2xen/pDS4QlrFZGcGNh/AphCN3U4Sw+p6DS0vwQbSWwpS1O9kBaCFlqqVcSAkoAIr1BgdU 7pMXgBkUwju8gMvWqvzryQIpBH/JgRSCH3AgqWXiUh2MRI38FcJ9IUUmyhS5w3JdYmvclftkokzRb 1u46Nzjyv0yUaaYd0+KBwCLx4t4M/zIs3D/251KhWrFPumvA0EWg/mPMgmCrRFRK95M9ZaHehVCzjRzFf3jjfxwD8XS6Dc1Bm4U8ZwU IkBiw7v9QM7mYAoBAGS8vfDwtjh24DETGblGGMLinqADPDiTu+ 2FnwQZzk3GrxYeCjScW1rtSgRuhDe3KedDyHS4sFMuVSXTvcJO gUmS6V5hl/+B3CU7vR8lDoNAkJePhc5DvLS0/z2GobG4E0GQlxlUiDkzOdZSWNaKsWIEQV5aUCEQBEEQeVAhEAR BEHlQIRBkwXn69KnT6ezt7e0OM3p7e+/fv//06dPFvkNImIIKgSALjtPpvHnz5k9hyeDgoNOJpbWIPKgQCLLgs I/qi60F8ty7d6+3t3ex7xASpqBCIMiC093dvdhCEIzu7u7FvkNIm IIKgSALTnd394MHD6anpxe7I1Kmp6cfPnyIChGM5qLM7y6Llgy eMx/XZwqa+fxN0QaTw402i+mLzMzj+szjx7/4h9l6seN+4A//UXPRP7xHk5xLhpsVJtHZvc3aHGAD07nBOVw42zdUiBeFn3/++cGDB/39/b29vb29vS6X63//938Xu1NISHR3d4ehPLBMT0+jQsgyfeuS7ZucLz7XZx7XZ31hLm 4c5l6oEFQhpgcq8k/ImO+s/IoB2a/Ao8tWg2DLmRWi9fvPUSEQMU6ns76+vkpMbW3tnTt3FrtryMyEu QkO8+4tDtPtpQa92dZxv6ko87tL9zvPnfrSXMW+QSGYQkwPnDP Kmu/M4/qTF2/7neZRU9EJ0WYzKsRIRV6A478gCkHuNhj+nLAsgn01UOJH5obxh R147JtbzfcSoasLfE4Bzsvmj9gXZbOTidoGRVPQDZUd2iq8G+z c4t6JPCVvDh8xb2RoBUP/RieYSmloaKgqMA4HTvsZ7oS5CQ7z7mVMEbgAABv+SURBVC0OV0 u+OG6sGPRFmfy9wObv5KJM0/0Xvvu2oqXP9WQaAGDyp6s2YyDr/6j+1Inj+szj+i+yT4SqEK1Wdpdv/nl3hi2bi8JQIUhtWiQTvbPwxmMC4Bmr0ycu4d7tumDYNQrfzDb k8XBt9s4VEaqEg9XPoYRP7nWq3lnzuLfYyr/hldg1EQwtmXVn1LxV+p5Up9MZRB5Ybt26tfCXisydMDfBYd69x WHwnPn4ie+aHsnkIXjkFULC9JPr5ZxCfFHaLlr1qK7wc33mcf0 J87mmcwFVRMK9f+ZnHtdnHv/8HzlZWcf1mcczDfnfVnXek4lghaVC1KdFiWc0Y+dVXEhECsHiL NdEy72Xe77hJv5Urslqe0yAuNsy2dd6v2UeBQBiT1axLwwvveU B8IyVsnPAsa/+5yfyZGceZQ/Hva7V+6raX375paGhwasEfX19U1NTADAxMVFXV+ddXlNTgzmJc CbMTXCYd2+ReNT8XXbm8UzT119mftsgnX0MAGZUCK+BZtsJc5X ITt+uthzPPK7P/PzrioHpwfOhKsTVUnFUimvH8368/iRQB8JJIW7mblIwcYea5GbOcjWZNewMaMolCdv+foGLBJVraMX y5PTDG5eo6N98mCyZR+ix9f0Z5h6QUQgAV+HbvliNINSzNPpNT SE/x5HzsmFXzFI2NrUlpYwLD5HBsk/e+S3NcP38pGyQADhMiTQTva9SPO0XF+ASzLzGLdmUM+CbONrXN 15R2LlI69OiRIEmfnvf5T98+FDoKwwNDQ0NDfX19YFf6OnevXu B7xCyyIS5CQ7z7i0ek8ONZ83ZxzOP67NyTldck5rFWShEVv6FP pHKDFZ+fYK17JU3ASBkhXDVFMgnITKPZ5deFTsSYakQ/BzIkfEaw/kbbp//QOoOxtCRewtvuAmAZ6BwdyRvcMs1tIKhE9Ib7hLgAvS+yQZGzG/xj+SBkFUIuHMyiXsYH7Vsi1BtyqgZmwQg4w2+SY1q05TMus86P QCeWzX6T06PAAA4vlqjoiP3Fg542PnF928+XBdQIWrTlLI+BKs BdyyJjJwPwdBrcgXTETP0DqsbfNNCbDvpzT7LZiBYhejr6/NfiIQnYW6Cw7x7i0xzUebJouKvMzM///qC2NDOzoc4nn2qht9ssCKPjS9Z/nmbXRCyDwGTw43nz7X0PZoEAJh81Fdzhi+FOvHdZZFEhKdCAIC rszB14xIVrWCUSzYdujhOgJuP7H2rz8C6rbtoRZJlnFMI3ypSn ar0Og0j5o3MTBP2yisElGtYhag7uFyc+G3V/YadGLVyfwQTd6hBIGNAyjVKRbyuLcTImP9scSplhM9LcJZrouX W8goBHUfZqYF2WR/zISZB0Amgv79fIg89PT0AMDY2JrscCU/C3ASHefcWGTYPMd1l+1Kf88N10ZrQ8hA3a09zwx0+P934GGC6v 8LMxpdONfCWdhYK4ceT+lPyShC2CsHiGWst3L9KRSti0upJgDl B1xscnEIIUhek+uPltDKtDgA69XGKGSfsDe5DDHy1Rm4WuWS71 74rlyRs+6Sw/S4BgNaMVYJpn0PB1ZS9J36Jii1VOmD7z7/9Rhh3IoO2VG9gbVf2xa93iONOfGr6fWs9608ok+2Cqx0ZGZEow dDQ0MTERCDHAglPwtwEh3n3FodHV9p6pgG8tUw3K0z6L0rbA1W yvhBtLrdh4RQCAICdYznqYC1cz3pDnMH2IVUInzB0HI3npCIYw fMQpGwPP6uoDMR947zhr+/8luYmoJ69Qojp1McpGFqxPK1ebu3jkt0RkjgSX94aGSNIYnt59 OiRv68gG3q6f//+nDuNLDRhboLDvHuLwmDl1ycM31S0/zTZXJT53aX7TUX/+PxryZg3OR9ieuD81yc+N1hsNT23nkwDwORPV89/ww+Zzq++KzOcwr8FdEoeXbYa9Flfn631Hr393Ck+yiStlQpLH8 LVVNslzFLXpimZqIO1bOwo6mO5SZ39FYILLqVolMFz1Cwz1DIF zmQIyqxGzVsVjKaczYKs+tvlkOuvSKvlaGHLLQ8AeG7V6NaoaA VDv6bnO+2yZ+srbrgJAHl8o3BnjF8ciY228Z6NVA6fPn3a2Ngo VAJ2KLVEHurq6rCWKZwJcxMc5t1bJCaHG8/me9+cYf62KpRM9f+0FRsC2n0u6xCyQjxqPvvVCX3m5yfMZe1sn VKXLTvwXsYKiQ6Eo0K0HF5JR6zeX3rDTQAmx2p9aWFw5GxWKmI 0pWMeAPL4RsXRHYkZrQRkFcI7oExo2d2VKSu9RxMw03iIx5X7I/lkMhv7it9rdQFcOrxiVUrpDTcB4m5Mj1PEHLoE0kz1SI3u7bTq gJlqGDmZJI2eRWw2XOcEhtSn+Y2WiNGUu0SH4B0LWr5ky+Vy+X sMEm7fvh38c0IWl8U1wf/93/+lPXQwyGs/UCGC0VwkST/41sjlIaYH/nlKTiROfGltDmxX5fIQt6vyvbsXccOlp/urC+RE4nNDUf2Y34i+MFQIAE9/6eFtK6KUCoaOiFrxZmrpgEewigvK0xFR8VsPF3a5AOQVgrWb4h x1UIUIOqZaOsw7++Ig4apa4/mM+kdF/DC3yf7SlMRoX7Vraf9kQIWAyf7ST955Q3BRgusFIOMNZs2WqCi lgiu0NTf6D/bmB0YIKrjEjI6OBpGHgYEB2b2Q8CE0E+xqMn/AffEiI9fsyp6XlxFMTU398Z1Ehlb8694///LLL8/QPURKwEz15HDjj6d4/yPT8LWl+GL7T7JDKnhkM9VeH+Ibu3Csw+Rwyzlr/hfsC6NOZH+R/925lmG5o4enQiALwZMnTy5fvizRhoaGhtA/KmQRCcEEu+wa0csIdJsimOiDtc+mEb/88su/7Pmz9/npr//3L7LTyaFCIIFAhXhh+PXXXx8+fDg4ONjb2zswMPDgwYOff/55sTuFhEQIJph0f5WS2yMQhNaMVXRESuXcT/r06dN//3ifJMj5/z45MKfuIa8oqBAIsuDMxQQ7stc/U1kdHNN/KlfnrTim/3Qeuoe8GqBCIMiCMwcTPGLeyCjfPv1cXu6OCoEEAhUCQRac2Zp gdixn6GP7nxFUCCQQqBAIsuDMygSTQeveaEXMbuvg89EHVAgkM KgQCLLghG6C51Ee9J9lyOYh9J9lzLl7yKsGKgSCLDghmmDSc3L H/HkPT58+Tdn/kX8tk3/BKyoEEghUCARZcEIxwaQnZ2vkPAeXpOMh/u3DX3/9dW7dQ15NUCEQZMEJwQT/T8lumYgQ82wFrwAwNTWVtG0LQyv+ZQ+OqUZmDSoEgiw4+F4m5A UFFQJBFpwwN8Fh3j1kEUGFeDH4+eefHzx40N/f39vb29vby74DfLE7hYRKmJvgMO/ec4U4623Ff9CZ1VqjOj0vMedc0TXnPCSG+quStEa11pgqO3FMG IMK8QLgdDrr6+slr+2rra29c+e5jLhFnpkwN8Fh3r3nyCO7JV+ tNYrbqX8EmH9sFqBCIAuE7IxyXhyOZ//yIgtOmJvgMO/e82OoervWqNYa3ysb9QAQ950a2/e7im+gDzGPCuEwrPOf7KFcw05J7cheL1etsd47R6hn4Lzhg8QV S1Q0N72E7IQKnv7Sz95/MyZSwU7hsNJ/QghZyN32whTfwaVzOQAZtPlmtpjlWjHjlm3cnHGpcpPqCalNU7 I3QXYWPKfTOeP0Qbdu3ZrpypFFJsxNcJh37/nB2/Gk767d8f/hekZtRdbET01qrTH20wKNrccZyirxkf0VwjPYrMspSEg3qrXG1 3XfHrCzp753Kseo1hrVOfW3AQCg9kyeWmtUG2qHAACg5axFrTW q0212AgBTfTXn9h7Pi2UjY6aqJpfopB98V6U5ZlZrC3P7Z31Ln q9C+LbKXi9ZAkB6Tu5cEbF0bQo3qSdMjrUUpiREqFbsK/OZf9L91YaldOQO/fmuB5MAQNwjLYUp6yIVqo2GG0H72v73GD9x8s1HxL4JJ9BsccH XShkxv8VvptpdIp1zSHTNNalR/AH9Jpj75ZdfGhoavErQ19c3NTUFABMTE3V1dd7lNTU1mJMIc8L cBId5954fpCtDxweXMvL/ZKmq6HvCzxfZpTtqkgSg1ha0TwRf5SWAQpDWcxvSJUEt4+uG2u sAt89b1VqjWlv8vRsAbmTq2bXWU+MAMJx7wqjWGmMtbQSma4ss sZLImK6s0u07Kd/YfWdH2CgEadPFKVSbsrslRpdcN2yKUG3KYTcldQdj6IhdhXelW w1eapxxoJGz/PBHR893PWTnlD6brGRoBbMu2wEAMGrZFsHQCiY6uXRsEsjdMk0 kQysYOsHgmHGtlA79az4hEU+TJ8FdslPlkxzf7NYsDx8+FPoKQ 0NDQ0NDfX194Bd6unfv3gzXjiwqYW6Cw7x7zxMyfOnAMbPAqpo 2FLQ5AYbsRWqtUX2k9PtbUwDTE10XkrRG9qk8yCof8grRl3WMN eg2260pIE9aS8/Eao1qrWlf9RMYq31Pa1RrTan100Jbr7n4BMbr93hXcZvlpVT95 AEgbkf2CaNaa0yyDfv2OlZ+8W7AWufghItCuEt2qgLEZEj1x8v pCI2dcNEbucmchQSarFSEVyG2nbwDAAM5m2kFQyuSLLzIuq27v BGw4GuldOrjFAytWJ92MClw+AgAvDNUqzQHWU9ieWqN8PplMxC sQvT19fkvRMKWMDfBYd695870RN+VXMuZBO7pPu9w8zgX8/FrKbVBVgmMsqxCcIbe+IdSfpJQ0pKiNaq1xtVnugDGLQbub1aE knKsq7XGWPPlkYvFaq1RnV5S6va6Gn4tv4V4g2a24Tnfi3BRiM r9EYxyX4AJtco1tGJ5Wj37h2r/heB9mkkhyjXeENCKP1rYWb3syQytYOi4rB7xhdAKJtlGgq8VH5 2fdDrB4OCzEVvNI7Id4YJRERo74bIRUR8LJbK/v18iDz09PQAwNjYmuxwJW8LcBId5954nzru+2lbi8FrYdlO2vA xoLvYFXiWYW3qWChFb0A5ex0VvS81hnZKujCNGdXppar5JrTXG mi9PAPT9cEZeIUyXJl4mhbBrvAEff7zHLNfQijVZ1yXHmeX7CX wKwUTGH652AXgVQhg14jVgXbYj+FrRwUl1qi94dceSKBs+Yhkx b2RoBaNMthOAuoPLaQVDR+wteezbYGREogRDQ0MTExOBHAskbA lzExzm3Xt+uFpSjpi2FjQ235oCmL5TU7qaj/lwieIjxafZzAR5Mn69q2F4Grw5ZLlVPuYQZQJxIuFE1XWYrj6d 5w1/cdu0lq/WGtXaPE3F0AQBgOmJe/21V24Rwe4vg0LM6EOo9l8AqE+Lknls9x5wFm+wIXcb/pbA0ApuGq/58iHcJXuVgujTnZNsoGmVrs2vB1wwSqUpJwDcpdEK5n2rN23x6 NEjf19BNvR0//79kK8cWQR6e3snJycXuxfyTE1N9fb2LnYvwoLm77+Rpny1xtjs qm4C4GpL1fk9px893wxBV3mRJo25RIWz3rY20BkBvBlptda4pb gPAEi9je8hm8GGAGM4LPqOcFYIid0ktg9nzENYd8jUhjprSqtd bNwmyTLOPaGLQzHCA86kEJMeYYFqT+Yar+fB+yK+nAGfaVila5 thrQC3dYfsy9dk+tyasUp2S3qjNyb19OnTxsZGoRKwQ6kl8lBX V4e1TGHO/fv3h4aG2FK0sGJqampkZASfMHim71xrFNSent5b1NzHGw1y95r F8u3aDKNay1c6DU7NuIojgEKAtNr1tKb46k2BrbhuK2QtfmYne 6a21HQ+iOTdiDjr7bY/sePAtea1Bltu46gHwlQhoDZNasRJ06FVXKqZR6aWqT4tWlLL9D +1/xHFKFetS4jwVQQ5cjYrFeuz/MpMezLXzKAQpNuwRhX9tr7ihpsAeG6ViquVzFsVQWqZgq71wm8 m08SX7w1GBR8dAuByufw9Bgm3b98OctlIOPD06VOn09nb29sdZ vT29t6/f99/xggEYZl/hWCNeMzuwhtuAkDcNwr3Riu85ar8NvLjIXZEK1QJ+3zjIRqPJN IKhmb+tdTl3cxl37dSGbF6f2HL2CQAAHk83FKYkhDBKFcdvwoQ MFM9VrI70t8cx2jKXdzZn3k8BO9qxOs7fQv5sRGigRGkXKP0X8 iPjRAXa42OjgaRh4GBAdkPBkEQ5NlZAIUQDT9WqJateOeQTTpW QU4hACRjqhVLo6MTP/p7yqYI1Yp9dsEgRTLeaP7ozZXLIhhawdB0zKo3d31W2M6Pqgtc yzTZX/rJO/ELNaaaHwaxUVy6xJW0MnSihX+LEj8MQhpV44+gTKsTHfnJkyeX L1+WaENDQ0PonxOCIMgcWBCFmGfI9SJzjWvm7V5mfv3114cPHw 4ODvb29g4MDDx48ODnn39e7E4hCPKS8yIoBIIgCLIYoEIgCPIK IK0mMq812CxXAs39MHzyy7xYrWlD3uWhZzrrk8oz37yuNb5+4k LL7N4Qy1ZVnebqo9LzNnxu1dWMBn5b6EKBCoEgyCuATL2pUa3N z2iVfWHR4irEo6biotdleluQNduXJ9Tb1DIj9WYBKgSCIK8Aol HN0xNdVdv9BxaEB86LxeywuNcNlTWjTwgAeH5qrizbmlM7a7lC hUAQBJkZ6Xsv+OHKJ6quQ1uq1qjWGjeeqtJl58Vqjan1wrUA4j Fxr+tO7y1quUkAYPrOldoDhvzXubDVjz8MSz0Su4V9/LfZfcPfivNrz737qUmtNb5+rDi3XWJt+VdxHKuQuB2ETAOAZ/BKruXbDZ+auOiT4UcbNzqP73PuuVzTN69rjUknCsUuiC30l054 QYVAEOQVIJgPwSkE3/IyWsUK0V+7M0Mc8DlSXgswVHlWGgtKP2MSz9IjpxCmWOGcEEd+ FBW98/Pc+V7nJ2aiukT6apB066kxEL6ig217cqyoEAiCICEQLA/BK0S6NV/yPH6i6jo8KTWzD+xnMq84CYDnYb+t9gYhHYePGNVaY1KxY4IAe H76Pj9Pzc3q40NWIbbbBglMt5wtEL1RQ9zPgHEhcutKx6jLAwD guVX3gdao1hq3/zAmUIiCw018Bh6jTAiCIDMjW8vERXh4hbB4X7MmVIiujCNGtda ozhdHfbiXqvq1z6uEb8qVUwh+ciFZ8833M5APQe5eyzUVJIhnp ostaBf3mQcVAkEQZGaCvcZuTgpxqcz/RbBqrVGtr2gRbDVrhfBOOCqfh+CmFZI2SxsqBIIgyFyZu0L4RZ lu3fjmfPsEP/9P0ned7DgFz8PR5tZ+p/jQs1cIGDpv5WuZznETZXsmOhvP7Txqs7u5rv6fvBYXAHE3/TW4QvBX/UHlIyDTsxuSAQCoEAiCvBLMXSEA+qu3i6M66nSbnUx32874uRG mv1x4IDz0HBQC4FH1mVOyDsoHlb2z8yF4GcNMNYIgSGCeRSHE0 X9BtetUX825vcfz2InhEo5bdZW9d8QP6nNSCAgypprcbdex9bU Z32hsjUdPBFUImO4+X/w7rkjX/s/Z3zZUCARBEEQeVAgEQRBEHlQIBEFeaChsC9cePRI2VAgEQcKRx beVr2ZDhUAQ5Pmz+LYPWygNFQJBkAVl8c0ctjk3VAgEQebG4ts vbAvdUCEQBJmRxTdV2BaloUIgCBKExTdS2BaxoUIgCOLP4tsmb OHQUCEQBPFnPq1Mh55ioqhqMssd/4vSRFLvnqIAKMM6SmMPsJmdYtZRDr/l5R9RS9+hRoByGChGI1oyh0swrKMYmmuqZdQeA+Waze4OA8XQX Dfkm4cqPUQlLKMYmmIiqTXbqNL+WXQs4M155oYKgSCIP/NnZQiVGkWplNTekrkfZA4KIbLOQUxzyB3wKgTbZnU5MyiEk9JE S4/PKKnDdaF2DBUCQZDnybyZGHcJpYqjCvUUs3WOz+8w7wrhoNbTl H2WHWBoyuCgACjbBxRDU5u/ogCo/lLqnXhKRVOMktr0EdXN+kmEuvAZFRdJMTQVFU/ltgoUglCGTRRDU5sNFOEPXrKbYmhKlUCV3qAIUMRNFe6mGJpio qlaQtk1FENTa5Kpt5dxF9Jt4Q6+7gD172/4FGK8gdrDdiaSeuczysVfKUNTmgPUUr7/qBAIgjwj86YQlm1UvJ4zVfoOCoAi1dRyJVXi9tnHeD01XkklRv MxHAtnPb3C4P2j8j+oGN7yWnp8CmE+REUpKUZJJezizLRXGKR/8EaToan1qdRbNGUe4XrSoadUuyk3UNpoKuaQjEJ429JEqslJAX Dm29vYvWrTRAt3WX0KwW6/cr8gSEWoD2mK4W+Od2FqFMXQVFqd6BSq/ZS7koqReBs0pbFTpJWKFy9cbxBdLENTuQOoEAiCzAPzpBAj1Fv 8o6t5K7U8lTP9+jjqLbNvA/MIRcapYTcFQHnGqF1Kzlz6K8T4MOUmFAA1VkCp4qgOViFoam8h 5QGKjFO6TVRMGkWCKITYh2D1ie2tbiWVWi1/IdIok5L60EoRoAbLqE3LBMvXUQ43tYu12mUUAcozRvU7eYVQUi qaYrZR434ODePn03jDR6xCqDZxymd9n2JoKkZDjRPKM0Z9GMVt VrnfL061kmr1+hBzDUOJFcInFaF/jRAEefmYH4XoEASX7lgohncd3CWUah3lEDy2ezopzRYqSul7KJ ZViM5CKnEFpeKNoJ1ViDeobv6MpIxilFRlyArBBsE6gII6anng dLowyuRpouJpilFS9hFqh1JslNdRDtYox1BNgt05heDVxTIiOH hoPsR6g1Q52H/ZtV4hkTR7APl5ZoUIcXdUCAR5OZkPheDNnLBxrgOhUqMofSuVG sU9tuvjqPXHqAceeWHg/uig4mnqWDPlEVr5Z1MItidpdVR1qs+ZCEkhaMraSq2nKSaeavZ QpJNaI+dDuG9QTSO8QkRTH26jGJparqHcgoOHkofwKkQgH4I9R YyGGvNQANSDLmqQBHRQnpdCUKgQCPJSMg8K4S6hVIJ8A7APvLx L0aGnlkdTKv5f3UrqrX9QHqDGG6jNygAK0Uqtoqkv+ykgVIOOU nkVYk5RJvMIRQgFQLXqqOX7qZQoX0IikEIIm2obNeKm9vr7ECA N+CRZBJnqESpJyTkHvuMHqGVKsfM3TaAQgfIQ3iN728oMVAgEQ RaEeVAI81YqXuer2AHgnAAunDJCvSWoGXVVU5uWUYyS2nSISg/kQwBVfYiKUlKqZdRhs8CHmFWmGigAyvQHSkVTW02+XjHv+57rZ 8hUK6mEbVS1kwKgBq1UXCTFRFKaPGoHrxCSWiZDk6jatVXn0xK hSBQGGA8hUQgQ1DLF7aKykn1BJ08npdnI1TIlHqD6PagQCIIsC POgEC9QS495puEaL3FDhUAQxJ/Ft03PpxFCkepgOepXvKFCIAjiz+LbpufTvt3pi/hj82+oEAiC+LOgdic8WXxzHIYNFQJBEH9eDqO/ECy+1UaFQBBkcUFJCIXFt+CoEAiCIC8Ei2/QUSEQBEFeLBbf0C9WQ4VAEASZA4tvvlEhEARBXhQW36CjQiAIg rxMLL4MoEIgCIK8ECy+KqBCIAiCvFigQiAIgiChggqBIAiCzJ0 5qIKI/w/p5cBHb5LR+AAAAABJRU5ErkJgggA=[/img]
Also good idea on selling my 'rare' ones, I though of that but not sure I really want to deal with it.
Old Apr 21, 2018 | 02:55 PM
tph88's Avatar
When I go to Tirerack I immediately see Back Ordered on the info page.. I suppose I could step through and try to order, but who knows when it will in. (tried to post a picture but didn't work)
I did think of selling it, but really don't have time/energy to deal with the logistics
Old Apr 21, 2018 | 03:03 PM
paris1's Avatar
Maybe it's a regional thing. I'm on the west coast and most TireRack stuff ships out of their Nevada warehouse. but you would think they could at least make an exception and ship to Colorado!
