Ticking noise question.
Old Mar 12, 2022 | 05:48 PM
Subperson's Avatar
Default Ticking noise question.
Hi,
I noticed today my car sounds like a clock ticking when it is first started in the morning or left out in the cold- Is this a normal Mazda noise?
2022 CX-5 NA - About 100 miles on it- it goes away pretty quickly
Thanks
Old Mar 12, 2022 | 09:15 PM
schmieg's Avatar
Originally Posted by Subperson
Hi,
Thanks
This is common on the MX5. On that vehicle, the solution is to floor the accelerator and press the start button or turn the key for about five seconds, then release the button or key, remove your foot from the accelerator and start normally. On the MX5, flooring the accelerator prevents the engine from starting, but allows it to turn which gets the oil into the head to lubricate everything. I think that would probably work on the CX5 as well, but I'm not positive. Maybe Callisto could comment on this.
Old Mar 13, 2022 | 07:02 AM
Hi,
Thanks
What you are hearing is most likely the fire front of the combustion exiting into the exhaust to enable quick warm up of the catalytic convertor. Mazda varies exhaust cam timing, fuel & ignition timing to enable this.
Old Mar 14, 2022 | 06:11 AM
Subperson's Avatar
Thanks everyone- Today it was gone? I will see what tomorrow brings !
Old Mar 16, 2022 | 05:07 PM
Anthropic's Avatar
This is normal. This is the AWS. Accelerated warm up system. It only does it when the coolant is below a certain temp.
rodster13
Feb 7, 2017 01:27 AM
dclayw
May 9, 2014 07:25 AM
joeyk11
Feb 6, 2008 05:12 PM
pcruz88
Jan 12, 2008 06:08 PM
the_gray_mazda6
Nov 19, 2005 12:37 PM
