View Poll Results: How safe is the use of a small spare (125-80-16). for cx5 awd?
Kills awd
0%
Acceptable for short distance
100.00%
Safe but undesirable
0%
Voters: 6. You may not vote on this poll
Spare wheel
Old May 21, 2022 | 01:11 PM
  #31
JohanEv's Avatar
Default Thanks
Originally Posted by CEB
Common sense is also following the manual. It says it is safe to use the emergency spare for the rear.
I really believe that all comments were helpful in making up my mind. I will use without any fear or hesitation the spare when needed, following the common sense (and Mazda’s cx5 manual) from the majority in this forum. Thanks a lot.
Old May 21, 2022 | 03:34 PM
  #32
I wasn't debating that at all I was just saying ... well re-read my response. LOL
Ya so you have no clue what I meant or the meaning of my response!
This is what is wrong many times with forums like this the majority is not always correct and actually often time they get it wrong!
I the best thing you can do is follow the owners manual to the letter unless there is a notification of correction from the auto manufacture.
Old May 22, 2022 | 11:07 AM
  #33
Peg leg often used by GEAR HEADS and HOT RODDERS refers to a none locking differential. If the differential is locking, limited slip ,posi-traction(posi), Detroit Locker or many other names that depicts both wheel rotating at the same time or same time under torque applied. Then using any tire/wheel combination that is a different diameter on the same axle could cause problems or damage to the differential.
Cane Toad 78
Apr 17, 2022 07:02 PM
Allan Panek
Apr 30, 2018 08:07 AM
dworthington77
Aug 6, 2017 03:44 AM
Londonlad
Aug 3, 2016 04:44 PM
pln64
Dec 14, 2015 10:35 AM
