rear bumper reflector falling out
I bought a new Mazda CX5 in December 2016 having driven my old one for 80,000 miles. After a few months the left rear reflector in the bumper became detached on one side and fell into the bumper. I asked my Dealer to look at it when it went for its annual service and they said it had been bumped and the clip broken. I inspected both the reflector glass and the surrounding bumper but could see no evidence of damage. They were quite adamant that it had been damage and that I could pay for it to be replaced but it would require a whole new rear bumper. They offer to try to glue it back in place and charges me £50 to do it!!
Has anyone one else had problems with there reflectors on a CX5 as I suspect there is a problem with the clips. Needless to say the reflector has now fallen back into the bumper. |
My new cx5 @ 1 week had same problem ;came adrift on one end; same response ; new complete bumper!!!
I told them where to put their new bumper,Went home looked & on rear wheel well is a 120mm square access panel to get to (I think the rear radar unit) which is attached to the reflector. I could see the cheap chatty plastic bracket which is welded (not) to the bumper, & to which the reflector attaches. I cut a piece of foam plastic approx 200mm cube & wedged it behind the reflector & holds it in it's proper place. Easy to do ; best to remove rear wheel to gain easy access. |
I fixed mine today. Removed the tire and panel as described by Sandra above - by lifting on either side of the 2 plastic rivets with a small screwdriver. I used a 4 inch steel "L" corner bracket to hold the reflector in place. I poked 2 holes in bottom plastic for screws, drilled the holes and bolted the bracket up tight against the reflector.
https://cimg8.ibsrv.net/gimg/www.maz...27a0c0fd93.jpg |
Same thing with my 2019. I just bought a replacement reflector ($100) and dealer said I can replace it myself or dealer could install. I did back into something that broke it from its mount.
I have to do the same repair. Has anyone tried gluing the lens back into place? I have great faith in GOOP, automotive grade .Is there anything within the bumper to glue the lens to?
| All times are GMT -5. The time now is 05:40 AM. |
