Passenger door lock broken Mazda CX-5
Old Dec 30, 2021 | 10:58 PM
Tasha9221's Avatar
Default Passenger door lock broken Mazda CX-5
Passenger door lock broken. Won’t unlock or lock with fob. All other doors are working. I have checked the fuse in the left side fuse box and it’s fine. Mazda are quoting me $150 just to look at it so wondering if anyone else has suggestions?
thanks
Old Dec 31, 2021 | 03:31 AM
BWJ's Avatar
BWJ
Try reset, take negative pole of battery 2 min. and reassemble the negative pole, then you may be lucky that it works.
Old Jan 4, 2022 | 09:35 PM
kaimanson's Avatar
So the door can be unlocked and locked manually from the inside?...only the fob is the one that doesn't lock or unlock that specific door?
Old Jan 4, 2022 | 09:58 PM
Tasha9221's Avatar
that’s correct. I can unlock and lock it by the manual lock (it doesn’t make a sound at all) but doesn’t work with fob. All other doors are working
Old Jan 5, 2022 | 05:25 AM
kaimanson's Avatar
Try the above recommendation about disconnecting the battery and keep us posted.
Old Dec 30, 2022 | 12:19 PM
dmaz99's Avatar
This happened to me, first with my right rear lock under warranty, and now with my right front lock not under warranty. Sounds like Mazda has issues with their door locks... anyone else run into this? I have a 2019 CX-5.
bigmik1021
Feb 26, 2021 04:45 PM
TeeJay
Oct 5, 2019 12:36 AM
jb0415
Jun 6, 2012 04:08 PM
TobyLee
May 5, 2009 11:15 AM
04nordicgreenrx8
Aug 19, 2008 08:01 PM
