P2150 and other errors
Old Jul 28, 2020 | 03:56 PM
Hjalti Vignis's Avatar
Default P2150 and other errors
Hello everyone.
A few months ago í posted error log about my 2016 2.2D skyactive CX-5
Since then I have replaced the PCM, engine wiring harness (Only the big connection), tested new pair of injectors, replaced fuel filter and MAF sensor. All without any luck. I still live by the P2150 error. - - Fuel Injector Group B Supply Voltage Circuit Low. COM 2 ground short Ground short upstream of cylinders no. 2, 3 injector circuit (So injectors on cyl 2&3 do not get any feed from the PCM)
Most sensors have been checked with oscilloscope, crank showing perfect signal.
Here is the error log. Is it time to scrap the car or is there a magic solution.............
===TCM DTC U0442:00-6C===
Code: U0442 - Invalid Data Received From ECM/PCM B
Status:
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Transmission Control Module
Freeze Frame :
-DTC: --- - DTC That Caused Required Snapshot Data Storage
-LOAD: 55.69 % - Calculated Load Value
-ECT: 27 °C - Engine coolant temperature
-RPM: 2970 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-IAT: 22 °C - Intake Air Temperature
-TP: 82.35 % - Throttle Position
-RUNTM: 6 s - Time Since Engine Start
-VPWR: 13.74 V - Control Module Voltage
-APP_D: 91.76 % - Accelerator Pedal Position D
-APP: 91.50 % - Accelerator Pedal Position
-SLIP_VALUE: 39 1/min - Absolute Value of Slip
-HTM_DIS: 0.0 km - The distance travelled since the High Temperature Mode was activated.
-PADDLE_DOWN: Off - Paddle Shift - Down
-PADDLE_UP: Off - Paddle Shift - Up
-TR: error - Transmission range
-GEAR_SEL: P - Gear select position
-TSS: 2972 1/min - Turbine Shaft Speed
-OSS: 0 1/min - Output Shaft Speed.
-TFT: 20 °C - Transmission Fluid Temperature
-LOCK_UP: OFF - Toruque Converter Lockup State
-MST_REC_SFT: - - Most Recent Shift Event
-SE_TYPE: No valid data - Most Recent Shift Event Type Identifier
-SC_STATE: Active - Shift On Control Status
-SFT_CTL_STS: Active - Shift On Control Status
-OP_SW2: Off - Oil Pressure Switch 2
-OP_SW1: Off - Oil Pressure Switch 1
-OIL_PRES_SW1: Off - Oil Pressure Switch 1
-OIL_PRES_SW2: Off - Oil Pressure Switch 2
-SS_ON_OFF: On - ON/OFF solenoid
-SS_ON-OFF: On - ON/OFF solenoid
-EOP: Off - Electric Oil Pump
-TORQUE_DES: 460.0 Nm - Desired Engine Torque
-G_INHIBIT_1: Off - Gear Inhibit - 1st Gear
-G_INHIBIT_2: Off - Gear Inhibit - 2nd Gear
-G_INHIBIT_3: Off - Gear Inhibit - 3rd Gear
-G_INHIBIT_4: Off - Gear Inhibit - 4th Gear
-G_INHIBIT_5: Off - Gear Inhibit - 5th Gear
-G_INHIBIT_6: Off - Gear Inhibit - 6th Gear
-G_INHIBIT_N: Off - Gear Inhibit - Neutral Range
-G_INHIBIT_R: Off - Gear Inhibit - Reverse Range
-OP_SW4: Off - Oil Pressure Switch 4
-OP_SW3: Off - Oil Pressure Switch 3
-EOP_RLY: Off - Electric Oil Pump Relay
-OIL_PRES_SW3: Off - Oil Pressure Switch 3
-OIL_PRES_SW4: Off - Oil Pressure Switch 4
-UPSHIFT_REV: Off - Upshift Record By Engine Request
===END TCM DTC U0442:00-6C===
===PCM DTC P2150:00-EC===
Code: P2150 - Fuel Injector Group B Supply Voltage Circuit Low
Status:
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
Module: Powertrain Control Module
Freeze Frame :
-LOAD: 69.02 % - Calculated Load Value
-RPM: 2965 1/min - Engine Revolutions Per Minute
-IAT: 23 °C - Intake Air Temperature
-MAF: 20.35 g/s - Mass Air Flow
-ISV_POS: 82.35 % - Intake Shatter Valve Position
-FRP: 148050.0 kPa - Fuel Rail Pressure
-FLI: 34.12 % - Fuel Level
-WARM_UPS: 0 - Number Of Warm-ups Since DTCs Cleared
-CLR_DIST: 0.0 km - Distance since diagnostic trouble codes cleared
-BARO: 101.0 kPa - Barometric pressure
-VPWR: 13.59 V - Control Module Voltage
-TP_REL: 82.35 % - Relative Throttle Position
-AAT: 23 °C - Ambient Air Temperature
-APP_D: 91.37 % - Accelerator Pedal Position D
-APP_E: 92.94 % - Accelerator Pedal Position E
-TAC_PCT: 82.35 % - Commanded Throttle Actuator Control
-ISV_DSD: 82.35 % - Intake Shatter Valve Control Desired
-FUEL_TYPE: DSL - Type of fuel currently being utilized by the vehicle
-FRP_ABS: 148050.0 kPa - Fuel Rail Pressure (Absolute)
-APP_REL: 91.37 % - Accelerator Pedal Position Relative
-EOT: 28 °C - Engine Oil Temperature
-ECT2_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT2: 135 °C - Engine Coolant Temperature 2 - Voltage
-ECT1: 27 °C - Engine Coolant Temperature Sensor 1
===END PCM DTC P2150:00-EC===
===OBDII DTC P2150-C===
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P2150-C===
===AM DTC None===
Successful DTC reading, no error codes found
Module: Amplifier Module
===END AM DTC None===
===ICA DTC U0401:00-08===
Code: U0401 - Invalid Data Received from ECM/PCM A
Status:
- Previously Set DTC - Not Present at Time of Request
Module: Smart City Brake Support
Freeze Frame :
-VPWR_IG1: 13.90 V - Module Supply Voltage (IG1)
-VPWR: 13.90 V - Power Supply
-ECT_STATUS: 0 - Under 80 degrees C - Engine Coolant Temperature Status
-CFG_STATUS: Config Complete - Configuration Status
-APP_STATUS: Over 20% - Accelerator Pedal Position Status
-RPM_STATUS: Over 1500 rpm - Engine RPM Status
-SHIFT_STATUS: P/N - Shift Position Status
-VSPD_STATUS: Stop - Vehicle Speed Status
-IG-ON_TIMER: 33 s - Times Since Ignition Switch ON
===END ICA DTC U0401:00-08===
===ICA DTC U0415:00-08===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
Status:
Freeze Frame :
-VPWR_IG1: 14.20 V - Module Supply Voltage (IG1)
-VPWR: 14.20 V - Power Supply
-IG-ON_TIMER: 34 s - Times Since Ignition Switch ON
===END ICA DTC U0415:00-08===
===CMU DTC None===
Module: Connectivity Master Unit
===END CMU DTC None===
===4X4M DTC None===
Module: 4X4 Control Module
===END 4X4M DTC None===
===ABS DTC U0401:00-68===
Status:
- Test not complete
Module: Antilock braking system
Freeze Frame :
-TOTAL_TIME: 124358405 s - Total Time
-TOTAL_DIST: 74177.0 km - Total Distance
-IC_VPWR: 14.00 V - Instrument Cluster Power Supply
-AAT: 20 °C - Ambient Air Temperature
-PWR_MODE_KEY: Running (Position 2) - Power Mode Key State
===END ABS DTC U0401:00-68===
===EPB DTC U0401:00-08===
Status:
Module: Electric Parking Brake
===END EPB DTC U0401:00-08===
===DSM DTC None===
Module: Driver's Seat Module
===END DSM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===AFS DTC None===
Module: Adaptive Front Lighting System
===END AFS DTC None===
===SSU DTC None===
Module: Start Stop Unit
===END SSU DTC None===
===EPS DTC None===
Module: Electronic-Controlled Power Steering
===END EPS DTC None===
===F_BCM DTC None===
Module: Front Body Control Module
===END F_BCM DTC None===
===IC DTC None===
Module: Instrument Cluster
===END IC DTC None===
===FSC DTC None===
Module: Forward Sensing Camera
===END FSC DTC None===
Thank you for taking time to go over this error log
Old Aug 19, 2020 | 05:13 PM
Anyone that might have an idea of what could be causing this error?
Old Aug 20, 2020 | 08:45 AM
Has it had any accident damage or repairs carried out in the previous 6 months?
Old Aug 30, 2020 | 04:56 PM
No accident. But previous owner said that petrol went through the system when he accidentally filled with petrol but not diesel.
Old Aug 31, 2020 | 07:13 AM
Has the fuel rail pressure been tested against spec? Petrol thru the high pressure pump usually ends in disaster.
Old Sep 4, 2020 | 09:45 AM
Yes full pressure there.
What is weird that there is electrical error, not mechanical.
jakej1978@gmail.com
May 24, 2020 12:24 AM
drflanders
Jan 26, 2020 11:06 AM
mango02
Dec 27, 2011 09:31 PM
cassincali
Nov 3, 2010 09:46 PM
the_gray_mazda6
Feb 4, 2009 06:15 PM
