-   Mazda CX-5 (https://www.mazdaforum.com/forum/mazda-cx-5-54/)
-   -   Mazda cx-5 2014 diesel 2,2l (https://www.mazdaforum.com/forum/mazda-cx-5-54/mazda-cx-5-2014-diesel-2-2l-54677/)
Amene123 Oct 22, 2024 01:04 PM
P1200
Mazda: Injector Range / Performance
Status of this DTC
Test failed (most recently performed test)
Test failed this operation cycle
Pending DTC
Confirmed DTC
Test failed since last clear
Engine state when the fault(s) appeared
No data available. ALSO red rectangular symbol is not diapers
😴😴😴😴 I spand a lot
sidooo Oct 29, 2024 09:34 AM
This usually indicates a problem with the amount of fuel being injected into the engine. This could be caused by a faulty injector, a fuel pressure issue, or even faulty sensors (like the fuel pressure sensor or MAF sensor)
Callisto Oct 29, 2024 10:19 AM
Originally Posted by Amene123 (Post 229385)
P1200
Status of this DTC
There is really not a point to guess and please I recommend NOT to take "guessing" suggestions from members!:rolleyes:
There are exact steps and an order to perform them to correctly identify and start a procedure to correct your issue.
The first basic step to resolving your issue is to get your ECU scanned in 3 areas and see what all the information is. PLAIN AND SIMPLE!
Callisto Oct 29, 2024 10:20 AM
Amene123
Callisto Nov 6, 2024 10:00 AM
Originally Posted by jakasspeech1 (Post 229872)
You're right!
And a dozen or more other things. Stating he is right tends to be vague. But I did get a chuckle from this and other responses from you on other threads. :)
