High pitch whine 2019 CX-5
Old Mar 31, 2022 | 04:14 PM
tripolitan's Avatar
Default High pitch whine 2019 CX-5
(Zip file with 2 sound files attached - Mazda2.m4a is clearer)
I'm hearing a high pitch whine that persists for about 30-45 seconds AFTER the engine has been shut off. Car was purchased brand new in Feb 2019 and I noticed this from day one but it wasn't nearly as persistent and went away within 5 seconds of shutting off the engine. Just last month I started noticing that it took longer than a few seconds to go away and now I can hear it while the engine is running as well.
The sound is coming from the general area at the back of the car.
File Type: zip
Old Apr 1, 2022 | 03:22 PM
BWJ's Avatar
BWJ
Try to untight the fuel cap a little.
Old Apr 4, 2022 | 07:47 PM
tripolitan's Avatar
Thumbs up
This is one weird suggestion that worked! (Thank you ). Did it have anything to do with the fuel pump?
Old May 16, 2022 | 12:24 PM
tripolitan's Avatar
Well, the whine came back...untightening the cap doesn't appear to be the solution for this problem. The noise is coming from the exhaust system roughly 3/4 of the way back, around the rear wheels.
Old May 16, 2022 | 12:32 PM
BWJ's Avatar
BWJ
There is a bulletin on fuelpump on some WIN´s the impeller in pump and non-return valve can be faulty, let dealer check it out.
Mine was replaced under warranty.
Old May 16, 2022 | 01:57 PM
tripolitan's Avatar
The whine is there during an long after I shut off the engine (20 to 30 seconds after) Doesn't the fuel pump shut off as well?
Old May 16, 2022 | 03:05 PM
BWJ's Avatar
BWJ
Yes pump shut off, but if non-return valve is leaking, the build up pressure i fuelline will leak to fueltank thru valve, whine sound.
If you, when you hear it,
turn on the ignition without starting engine - i bet the sound disappear. (turn down radio and shut off aircon first)
Old May 16, 2022 | 03:36 PM
tripolitan's Avatar
If you, when you hear it, turn on the ignition without starting engine - i bet the sound disappear. (turn down radio and shut off aircon first)
Yes, the sound disappears. I'm surprised there was no recall. Thank you for clearing this up for me.
Old May 16, 2022 | 04:39 PM
tripolitan's Avatar
Old May 17, 2022 | 01:38 PM
BWJ's Avatar
BWJ
Also see these tread https://mazdas247.com/forum/t/just-r...2#post-6755818
