Help multi codes after engine change
Old Sep 25, 2024 | 12:00 PM
paigem's Avatar
Default Help multi codes after engine change
Had an engine swap done last week due to some malfunction new engine was clean with only 1500 miles on it professionally installed. It’s still at the shop with 14 codes she starts up quite and runs beautifully but codes are p0098,p0108,p0522,p0524,p061b,p0098,p0455,p0457,p0 014 we did notice blue acid coming out of the battery ports and will be replacing the battery but what could cause all this at once the vehicle is a 2020 Mazda cx5 with the old engine having 115000 miles I will post old video of what caused me to do the swap and later today a video of the new engine
Old Sep 25, 2024 | 12:14 PM
ok so start over with the scanning. All those DTC means they are accumulated with having sensors disconnected and likely moving the crank while the ignition and ECU was being powered!
That said come back with a revised DTC info.
In the mean time check the battery by way of load testing.
Clean all battery terminals and most importantly the cable at the starter and the ground. There are indication of a poor ground!
MMZ
Oct 4, 2022 11:17 AM
Liza Farnsworth
Nov 16, 2019 02:13 PM
davbell22602
Feb 21, 2010 06:37 PM
leewalters
Nov 5, 2008 12:28 PM
mzdaspd304
Jul 8, 2007 03:47 PM
