Fluid or Rubber Engine Mounts
Hello everybody,
I have a 2013 CX-5 That I recently got as a bit of a fixer-upper.
Its been good so far, really easy to work on and a good commuter car.
However, I believe the engine mounts are going bad, and I would like to replace them.
But in doing so, I see a couple of engine mount-varieties.
From what I understand:
And are the AWD mounts different from the FWD mounts? Mazda parts seem to suggest so, but I can't understand what the difference is. Again, I'm mostly trying to be informed.
Your input would be greatly appreciated; thanks!
(This was also posted on Mazda247)
- Passenger side engine mount (Top) is fluid-filled
- Under Engine to Subframe (Dogbone) is solid
- Transmission is also solid
