Drawing power from battery at idle
Old Jul 10, 2021 | 05:56 PM
  #21
Gerald Mucci's Avatar
You DO NOT connect any accessory directly on the alternator battery lead of a ECU/ECM alternator output controlled charging system.
Even the starter factory is first supplied directly from the battery and a piggyback lead to the alternator.
Your ECU in the MAZDA can not effectively adjust the charging rate of your alternator..... so I am not sure if you would damage your Alternator ,ECU or battery maybe all 3? There are some thing electrical you just don't cheat on!
Still no direct answer to a direct question.
Old Jul 10, 2021 | 06:19 PM
  #22
When you add none factory electronics you either piggy back an existing circuit after you verify it will support the additional load (must test for both heat using a digital temperature gauge and also the ohms with all the devices at maximum demand) or you connect directly to the batter(always a better choice).
Old Jul 13, 2021 | 03:27 PM
  #23
Thanks. The battery it is, then. I expect the DC to DC unit (10 amp, 12 to 48 volts) tomorrow. I'll check back with results, only if I don't fry something.
Naseer96
Feb 4, 2021 03:27 AM
Lestorhm
Jan 19, 2019 09:04 AM
skunkerb
Jan 11, 2017 02:37 PM
Ecnesse
Oct 3, 2009 10:23 PM
Konthra7
Aug 26, 2009 12:15 PM
