looking at the Garmin Dash Cam 47 with constant power. Has anyone installed one of these? Best way to hard wire without having the interior look like black spaghetti?
Can’t help you with the constant power but I did install Garmin 57 at the front & Garmin 47 at the rear on my CX-5 by myself & powered both through OBDII port using Garmin OBDII connector. Parking mode is not critical for me and I didn’t want to hardwire.
I used the cigarette lighter between the seats in the arm rest because its always on with no problems. Pretty easy to hide the cords.
Good thought and install on your NEW dash cam
Unless you smoke: Cigarette power outlets are becoming extinct in vehicles. They are also prone to problems unless you carefully read the power requirements anything you plug into them. Dash cam is fine. You might want to consider pulling it and installing a simple dual USB port in its place.
