cx5 runs badly - rough idle - no power
Old Mar 15, 2019 | 11:50 AM
dmg53's Avatar
Default cx5 runs badly - rough idle - no power
2015 CX5 (2 L) with 126,000 miles. Has new plugs, new coils, fresh oil and filter. The idle is very lumpy....it has no power and won't go over 30 mph.
Engine light on, and tire warning sometimes. Car has also new battery, which improved the problem for a short while.
I thought to replace the EGR valve. Now I wonder if the car has one?? Nobody on line is offering an EGR valve for this car. This has been very reliable up to now; we have no extreme weather.....
I have an electronic code finder - what codes should I expect to see??
Any help would be appreciated.
D
Old Mar 15, 2019 | 06:12 PM
paris1's Avatar
Why don't you scan for codes and then tell US what you find. Instead of speculating about what could be anything. You describe an engine that's in limp home mode and, as such, should not be driven that way. Who's been doing the work on the car up to now? Does he know what he's doing? Have you taken it to the dealer for proper diagnosis?
Old Mar 16, 2019 | 03:19 AM
Without scanning for codes you are simply pissing in the wind.
Old Mar 17, 2019 | 09:21 AM
Arkainzeye's Avatar
I agree with these guys.. if you don't scan the CODE.. you are simply GUESSING what is wrong.. and up to this point, you have been wrong ....
Old Mar 20, 2019 | 12:14 PM
davmac's Avatar
Good advice so far. Your car is definitely in limp home mode, or as I've heard it called (more appropriately) engine protection mode. Stop throwing parts at it hoping the next one will fix the issue. Step back and troubleshoot or bring it somewhere that will do this for you.
Since the check engine light is on there will be some codes stored and your code reader should at least be able to show you engine codes that were stored and often freeze frame data (engine conditions when the code was set). Just be aware that engine fault codes don't tell you what to replace they only tell you what is out of range. The codes you see will help you focus on an area so you might more quickly find the source of the problem. Test twice, fix once.
Doggyx
Aug 11, 2022 08:49 PM
Leo5820
Oct 4, 2018 10:14 AM
tribute owner
Jun 3, 2008 10:27 AM
jimm
Dec 14, 2005 11:28 PM
