CX-5 Sticking brake
Hey all,
Recent issue with the CX-5 has me running in circles here... Rear passenger brake squeeking, OK, outer pad worn down to metal, so I replace both rotors and pads with Powerstop brand (use on all brake jobs in my driveway). This issue is that the rear passenger is getting hung up and/or stuck that you can smell it when you get out of the car. During service I re-lubed and re-sealed the caliper guide pins, wire wheeled the caliper bracket, and lubed the pad ears and slots. Still wants to stick when pulling away from a stop intermittently. My question is what is a likely cause, and how do I prove/test it? I suspect the following: 1. bad caliper, replace 2. bad electronic parking brake module, replace 3. Bad module in the car that holds brakes when letting off the brake on a hill or what not, no idea how to fix this if the cause... FYI this is a manual car and I'm worried if I dont fixt it soon I'm going to wear out the clutch as it already chatters when the brake gets sticky... Any ideas? Thanks, -Glaser67 |
Model year?
Originally Posted by m5xguy
(Post 200568)
Model year?
Want to note that I did not put the EPB in maintenance mode when I did the brake job or the last time I did it either. |
Originally Posted by glaser67
(Post 200570)
2016 cx-5
Want to note that I did not put the EPB in maintenance mode when I did the brake job or the last time I did it either. MC-10129575-9999.pdf (nhtsa.gov) |
Thanks for the response.
You confirmed my suspicion. I think replacing both caliper and EPB module myself would be cheaper than the dealership diagnosing and taking the same 50/50 gamble. Final thought; car holds braking when let off pedal in gear from rolling back, is this action controlled by the EPB module, or another module that holds the brake line pressure? If another module, I hope it's not the issue... |
(Post 200584)
... I think replacing both caliper and EPB module myself would be cheaper than the dealership diagnosing and taking the same 50/50 gamble.
.... Final thought; car holds braking when let off pedal in gear from rolling back, is this action controlled by the EPB module, or another module that holds the brake line pressure? If another module, I hope it's not the issue... |
