CX-5 Problems
Old Jul 26, 2023 | 08:13 AM
Neil01293's Avatar
Default CX-5 Problems
Hi, I've had my Cx-5 for a month and it's already throwing up problems.. the overall ride is good. A week ago the Engine Veichle inspection required warning came up (no warning lights on).. noticed the coolant level was low and the oil level was high.. booked it in with Mazda today and on the way the Veichle system needed inspection message came up. So Mazda have said the EGR valve is most likely faulty and needs replacing, plus the oil pick up line was at fault (slight juddering when pulling away).. Mazda don't seem to like cleaning things they only like to replace at great cost. I'm wondering if it'll be an expensive job to simply go to a garage and get both cleaned? Any advice would be great thanks..
Mazda CX5
2013
2.2 diesel
Old Jul 26, 2023 | 09:22 AM
Geluk's Avatar
At that age, you'll find it much cheaper to use a good independent garage.
Old Jul 26, 2023 | 09:27 AM
Neil01293's Avatar
Thanks for replying, I have found a local mobile mechanic who will come and clean the EGR for £150.. He did mention that if the EGR is knackered that some people have "by pass it" instead of the costly replacement
Old Jul 27, 2023 | 09:34 AM
lkj-17's Avatar
Default Fuel addictives
Did you try fuel addictive so to clean the engine a bit?
Old Jul 27, 2023 | 11:05 AM
Alexmed2002's Avatar
Certainly wouldn't hurt to add.
Old Mar 24, 2024 | 06:36 AM
lkj-17's Avatar
did you get EGR replaced or just cleaned? i got my one cleaned and P0401 came up again...
Old Mar 24, 2024 | 08:52 AM
Neil01293's Avatar
I got mIme sandblasted and completely cleaned at mazda, cost me a fortune but (touch wood) it's been okay since 🫰
Subperson
Dec 10, 2025 01:48 PM
Stuart2016Mazda3
Sep 3, 2023 09:34 AM
rhud
Jan 10, 2023 09:40 AM
RPH
Aug 27, 2019 06:30 AM
