CX-5 Problems
Hi, I've had my Cx-5 for a month and it's already throwing up problems.. the overall ride is good. A week ago the Engine Veichle inspection required warning came up (no warning lights on).. noticed the coolant level was low and the oil level was high.. booked it in with Mazda today and on the way the Veichle system needed inspection message came up. So Mazda have said the EGR valve is most likely faulty and needs replacing, plus the oil pick up line was at fault (slight juddering when pulling away).. Mazda don't seem to like cleaning things they only like to replace at great cost. I'm wondering if it'll be an expensive job to simply go to a garage and get both cleaned? Any advice would be great thanks..
Mazda CX5 2013 2.2 diesel |
At that age, you'll find it much cheaper to use a good independent garage.
Originally Posted by Geluk
(Post 218062)
Fuel addictives
Did you try fuel addictive so to clean the engine a bit?
Originally Posted by lkj-17
(Post 218087)
did you get EGR replaced or just cleaned? i got my one cleaned and P0401 came up again...
(Post 224469)
| All times are GMT -5. The time now is 11:35 PM. |
