CX 5 jack stand placement
Old Feb 2, 2025 | 11:58 AM
Rob Sellin's Avatar
Default CX 5 jack stand placement
I cannot find information on where to place front and rear jack stands on the CX5. The one YouTube source I found is incorrect, according to the comments. Thanks for any tips -Rob
Old Feb 3, 2025 | 10:10 AM
Point37's Avatar
look in section 7 of your owners manual (at least that is where its listed in the 2025 manual)...should have a section about changing a flat tire and shows placing the oem jack on the pinch welds behind the front tires and in front of the rear tires...but not sure what year cx-5 so can't confirm
Old Feb 3, 2025 | 10:16 AM
Rob Sellin's Avatar
Default Thanks
Thanks for your reply
I will lift the 2014 cx5 at the pinch welds.
Question: after lifting with a jack where do I place jack stands under the car to take the weight off the jack? Rob
Old Feb 3, 2025 | 10:44 AM
Point37's Avatar
the pinch welds are where i put my jack stands...my stands are flat so i use jack stand pads (link below)...1 pad could be used on the jack as well if needed...if i don't have to take the wheels off i use plastic ramps which can be bought on amazon, harbor freight, auto part store, etc. as they are much faster to use...i have not jacked up the whole front or whole rear so i'm not sure where those jacking points are
https://a.co/d/fHOZgbI
Old Feb 3, 2025 | 10:54 AM
Point37's Avatar
check this thread...not sure what year cx-5 you have...
https://www.mazdaforum.com/forum/maz...t-point-48395/
AntCha
Mazda CX-70 & CX-90
Jan 14, 2026 11:04 AM
New2Mazda2024!
Sep 16, 2023 12:26 PM
Raviy
Oct 7, 2021 09:23 AM
Litehiker
Jul 5, 2020 12:38 AM
Hermie
Dec 16, 2015 03:14 PM
