CX-5 heater core issues
Hello all,
I have a 2016 CX-5 GT with 50K on it and it looks like I'm having the same issue as you are describing. Check Engine light with P011A code (it does not have a block heater). It is intermittent and just today had the computer updated per the TSB for $115. The tech advised me that they had seen this before and the heater core was likely clogged and would require replacement for approximately $1100. From what I'm seeing in this forum it looks like this happens not long after the warranty is out and becomes a "cash cow" repair that happens quite often but running under the radar of most owners. I'm getting some heat but it seems lukewarm with the engine up to temperature so it must be a partial clog. Seems like the reverse-flush idea is a good temporary fix if the debris will flush out. It's sure a lot less costly. I hope Mazda monitors this forum and realizes the secret is out.
Mine did blow up. In the shop now with cracked head repair. Within a week of Mazda saying I needed a new heater core for a cost of $1,900, a temp warning light came on. I waited until the car cooled completely down and added fluid. Drove it to a mechanic only to find out my head was cracked.
There are YouTube videos showing how to access the heater core through the glove box. It requires the crimping of two well-sealed metal lines, but looks attainable by a descent backyard mechanic.
I have 2014 petrol CX5 with 93,000 miles. With the onset of winter noticed poor heat output. Lots of checks. Reverse flush made no difference. Remove glove box and feel heater pipes only warm, (after repair too hot to touch). Watch flaps move ok in response to heater controls. Do not waste any more time replace heater radiator with aftermarket copper and brass one. This has much wider tubes and will not block. The original is a very efficient heat exchanger with lots of narrow tubes but so narrow that they block. The one that I used had clips rather than crimping and is a well engineered solution. (I do think it is less efficient because of the reduced surface area.) The replacement is probably about 2 hours using U tube advice on how to replace without removing dashboard. Just remove as little as you need to as you go along and do not be afraid to bend the welded bracket that is in the way, it goes back easily! This is one of those problems where you go round in circles and it was always the heater matrix.
Hi All, I read the information you've shared here and wonder if I have a similar problem at hand. My car has 90K miles on it and about a month or so ago, it started giving me an orange check engine light that would come and go. The code was P011A and I found a number of TSBs related to it. One of them says if both ECT sensors are working OK, the dealer could reprogram the PCM to correct the problem. Yesterday the car displayed red blinking thermometer icon and said 'coolant temp is too high' as my daughter was driving it, and I could smell some unpleasant odor (like rubber burning). So long story short, it is parked in the garage and no one is driving it in this condition. I started the engine today and ran it for a while to warm it up. The orange check engine light came up (no red blinking light this time). When I turned the heat on in the car, I saw that it was just blowing cold air. This got me wondering whether I have the "clogged heater core" issue mentioned here. Is there a way of telling whether it is to do with the PCM update or the heater core? My Mazda dealer wants to charge $125 for 1 hour of diagnostics in addition to labor and material based on whatever they will find out. Has anyone had any luck with Mazda Corp on this or similar issue? Thanking you in advance.
You wrote that back-flushing while the core was still in the vehicle didn't work, but did you also examine it after removal, including trying to force higher pressure air or water through it? It might be helpful to others if you could find out exactly what's clogging it up, and how much pressure it takes to drive the debris out.
WELCOME TO THE FORUM
I am not sure the use of more air or water pressure in the procedure is recommended to do with anyone except those having experience with cooling systems. And even those that are it is not a way to perform the service! You can very easily destroy other parts or make a simple flushing turn into a disaster. And I would NEVER advise to increase air or water pressure until a clogged cooling system part cleared?
Mazda service bulletin 07-007/19 covers this. 07-007/17 is superseded.
This applicable to most of the Mazda range but it is the earlier models that are showing the issue.
Reference to contaminated coolant and need to refill with premixed (presumably deionised) coolant suggests to me that it is scaling of the narrow heater tubes that causes the problem. The onset of my problem at 93,000 miles suggests scaling is a progressive process. I would not fit a secondhand unit for this reason.
It seems that this system needs to be managed properly to protect it!
The 2019 bulletin relates to the coolant concentration of “anti rust” (corrosion/scaling) inhibitors being increased. That is probably the crux of the problem. As time passes deposition occurs on the walls of the heater matrix tubes, blocking them eventually!
Please in the future if you or other members are going to quote TSB written for and intended for use by skilled technicians read it completely and understand it completely! And please don't pull only some information you think supports your idea's!
Did you even completely read the TSB and understand all of it? I had to read it a couple times and I am supposed to understand all of that.... LOL Thats what I do for a living for oh about 5 decades now! lol There were parts that should have been SAE edited before approved for publication.
There was no chemical testing of the coolant nor testing the cooling system hard parts to base any conclusion that could be empirical. The TSB was also outlined with several tests to determine the condition and possible solution to remedy the concern. That is basically what TSBs are for. Unfortunately the internet has made available information like TSB that any Tom, DICK Jane and Hairy, can access and think they understand what the information is on them!
I already read that a member blow his breath in a cooling system part and determine its CFM rate comparing a completely different manufactured part. WOW!!!!!!!! LOL REALLY !!!! LOL
Totally disregarding the complete cooling system design and making WILD guesses about how something should be! While it may result in being true the method used is not fundamentally the correct or even a good way to do it!
Just to be clear it truly bothers me when some post information on a thread without doing the research . I feel sorry for the poor members reading it hoping to find a solution to a like problem that thinks it is accurate or empirical in nature or just the correct information will trust the information and act on it!
I know that ATOMIC you may take offense to my posting style and information and based on your username I am going to guess you are over the age 60. Please don't! I am straight to the point, and I don't pull punches! Even in the real world! I can understand "old school" ways of thinking and doing things pertaining to vehicles but the technology of the vehicles (2000 and newer) you and most on this forum are driving are no longer so DIY friendly. Many service procedures now do really require more considered reading FACTORY SERVICE MANUALS or if available Haynes, Chilton, Clymer etc. repair manuals. I suggest to really stop reading TSB's unless you are at least a currently educated auto mechanic, currently meaning in the last 20 years.
ASE
*CONSUMER NOTICE: The information and instructions in this bulletin are intended for use by skilled technicians. Mazda technicians utilize the proper tools/ equipment and take training to correctly and safely maintain Mazda vehicles. These instructions should not be performed by “do-it-yourselfers.” Customers should not assume this bulletin applies to their vehicle or that their vehicle will develop the described concern. To determine if the information applies, customers should contact their nearest authorized Mazda dealership. Mazda North American Operations reserves the right to alter the specifications and contents of this bulletin without obligation or advance notice. All rights reserved. No part of this bulletin may be reproduced in any form or by any means, electronic or mechanical---including photocopying and recording and the use of any kind of information storage and retrieval system ---without permission in writing. © 2019 Mazda North American Operations, U.S
© 2019 Mazda North American Operations, U.S.A.
* Under one or more of my business licenses I have a current permission to use TSB's, Mazda ,Ford ,BMW/MINI, MOPAR, Cadilac, under ALLData, and ASE. This may include most all offered distribution of sales from auto manufactures in the USA and Canada.
