-   Mazda CX-5 (https://www.mazdaforum.com/forum/mazda-cx-5-54/)
-   -   Brand New 2014 CX-5 Sport. Battery already died (https://www.mazdaforum.com/forum/mazda-cx-5-54/brand-new-2014-cx-5-sport-battery-already-died-31862/)
Rebecca C Jun 28, 2013 04:48 PM
:confused:
I'm not sure what I could have done. Does anyone with experience with this car have any advice? I'm pretty sure I turned everything off, radio, lights, etc. Shouldn't there be some sort of warning beep for lights left on anyway? I am afraid we got a lemon. Has anyone had battery issues with their CX5?
grim_reaper Jun 29, 2013 07:19 AM
Calm down and talk to your local Mazda service centre. The whole car is under warranty.
How long did you leave the car before the battery went flat?
have you had any accessories fitted?
beckyvoss Jul 8, 2013 05:29 PM
We had same problem with our 2013
At 252 miles our battery was dead after I didn't drive it for 3 days. Then at about 2600 miles it wouldn't start after I finished working and I had to have it towed. The dealer thought it was the battery so they changed it and I have done another 4000 miles without problems.
CX-SV Jul 11, 2013 02:56 PM
Originally Posted by Rebecca C (Post 139002)
:confused:
What did your Mazda service department say?
2014 cx5 Aug 10, 2013 09:24 PM
Wtf...
Got my CX-5 two weeks ago, and the POS wouldn't start after ~550 miles. Had to get it jumped by a Jeep Cherokee from the early 1990s. What a joke.
Will be calling my dealership tomorrow.
rich4205 Aug 18, 2013 06:53 PM
I had the battery completely dead the other morning on my 2013 CX-5. After the AAA guy jumped it we could find on reason why?
CX-SV Aug 29, 2013 04:58 PM
Any new info as to why?
jdude1 Nov 5, 2013 01:54 AM
cheap battery
ok soooo i have a 2014 grand touring cx-5 with 12,000 miles the temp. here was 18 degrees at night went out after work to start the car and it sounded a little weak barley noticable , drove it 3 blocks got out let it idle for 20min came back and all warning lights were on in the dash including check engine,
shut the car off restarted all lights off except check engine light - went to AZ got the code reader cleard the code , suspected the battery had it load tested battery was only 12.5 and was bad, called mazda - they said they put in batteries different than the ones they come from the factory with if they are replaced , im in wyoming small town no dealer, so i got the duralast battery group#26R 575 CCA got it installed car started strong ,
i noticed battery was smaller than original by quite a bit i will look to see if the next size up will fit for more CCA's - the original is a PANASONIC POS!!!! get rid of it as fast as you can it is chineese JUNK. im just glad i got mine checked befor the weather got real cold or i was stuck somewhere -- by the way put insulation around new battery cause there is none:(
UseYourNoggin Nov 5, 2013 08:01 AM
Good AGM battery: from Canadian Tire same as Odyssey http://www.odysseybattery.ca/
If you have lots of money get the Lithium: Lithionics Automotive Lithium Li3 Batteries
Wrap your battery in insulation. It will keep the cold and the heat off of your battery for better starting in cold weather and longer life as heat doesn't destroy it.
The battery shown is for my 2006 Mazda 6, but i'm sure they have 1 for your vehicle.
http://i1049.photobucket.com/albums/...attery2013.jpg
http://i1049.photobucket.com/albums/...tteryLabel.jpg
http://www.odysseybattery.ca/images/odyssey_labels.jpg
http://www.lithionicsbattery.com/ima...ng_battery.png
CX-SV Nov 12, 2013 11:35 AM
I'm still on original battery after a 1.5 years, no problem.
