Battery CX5 awd 2018
Old Oct 26, 2023 | 05:54 AM
CX-5 with i-stop needs a Q85 EFB, 650 CCA
Old Oct 26, 2023 | 06:11 AM
JohanEv's Avatar
thanks grim_reaper.
Old Oct 26, 2023 | 09:02 AM
chickdr19's Avatar
Depends on what you are willing to do to maintain the health of the battery. Even in the best conditions without a trickle charger frequently used to maintain 13-13.5 volts constant all automotive battery will start a slow decline. Also, without the consideration to add larger or a few more batter cables the factory MAZDA cables are not the best size in the long term.
I would at least add a couple or more grounds and addition large single cable from the battery to the starter. The starter has the greatest load effect and naturally some of us it several times a day.
If not willing to do these suggestions, then.... by using the same battery load tester (load tester that show test voltage before, during and after in at least the tenth scale better 100 scale) and the exact same setting, make sure to get the temperature of the engine compart and better the battery at the time of the teat, log the results, repeat every 2 months and you WILL see if the battery is starting to decline.
And that is just it. So much variation. In some of my cars I have used a NOCO trickle charger from time to time to top up the battery. With the current CX-5 I have done nothing so far. My 2020 Nissan Frontier is now 37mths old. Still the OEM battery as well with no maintenance done and running strong. My 06 Z4M sits unused most of the time and needs charging monthly to stay in shape. Battery seems to die every 4-5yrs with the monthly charging.
Old Oct 26, 2023 | 11:06 AM
Yes and statistically in the last decade if anyone get more then this out of a life of a battery it is extremely rare or the battery is on it lasts legs and the owner doesn't realize it until you read... "the car started fine I went shopping came out and it wouldn't start"! ?. LOL
The other thing I am sure you have read me post is that most have no clue how old the battery is in their vehicle. Its not that date code sticker nor is it just because you bought a new vehicle at a dealership. Most batteries retail is already several months even a year or more old and it is the same from auto manufactures.
Dealerships are the worst for testing a batteries ability to be discharged and charged back up. Anyone that ever worked at a dealership in sales capacity or lot service knows exactly what I am talking about.
Old Oct 26, 2023 | 02:09 PM
chickdr19's Avatar
I completely agree. All the dealership cares about is the car making it out of the lot. My FIL bought a '21 NV200 and the battery was replaced less than a year later.
Georgehnz
May 14, 2023 06:54 AM
Geluk
Nov 28, 2022 07:05 AM
arcamm
Mar 5, 2022 09:58 AM
CX5GGuy
Feb 19, 2022 02:54 AM
RobertG314
Nov 29, 2021 08:06 PM
