2020 Mazda CX-5 lost communication w TCM
Old Jun 2, 2023 | 11:11 PM
2020mazdacx5's Avatar
Default 2020 Mazda CX-5 lost communication w TCM
I am working w my crashed Mazda Cx5 2020 with a current code of U0100 lost communication with TCM. No front radar no cruise control and no front facing camera working. Car has check engine light on and i need to troubleshoot the circuit. Anyone knows where to get the TCM circuit diagram
Old Jun 2, 2023 | 11:52 PM
Has the crash damaged been repaired?
Old Jun 3, 2023 | 11:30 AM
m5xguy's Avatar
The ATX connector has pinout:
A (yellow) -pwr
B (black) - gnd
C (violet) - pwr
J (yellow) - starting system
E (white) and F (red) - HS-CAN
G (brown) and H (grey) - MS_CAN
Have you checked to see if the AT fuse is OK?
Old Jun 21, 2023 | 03:36 PM
Yes damaged been repaired i can film the car and put it on youtube. We bought a replacement radar from ebay and no luck i dont know if they blow like airbags when a car crash.
How can i check the wiring diagram. I have a power prope yellow and black got power
Old Jun 22, 2023 | 12:30 AM
I know the header says prius but its for the mazda. One reading was w radar connected and one without.
Old Jun 22, 2023 | 08:13 AM
m5xguy's Avatar
Originally Posted by 2020mazdacx5
.... I have a power prope yellow and black got power
Yellow and violet should have power, black should be ground. Test voltage with a multimeter - key on - one probe to the connector and the other to opposite polarity battery post. I'd have very little faith in a reader that's displaying the wrong vehicle. Forscan is one that definitely does support your vehicle.
Old Jun 23, 2023 | 05:56 AM
Are you 100% sure all the front wiring loom is in perfect condition?
Are you 100% sure all the earth points on the front & 1/4 panels are clean & free of paint?
Was the replacement radar calibrated to your vehicle & aligned using appropriate equipment?
Old Jun 27, 2023 | 01:35 AM
Vehicle has good grounds i double checked and the electrician has checked them as well. The original radar was crashed so i got a replacement and the info was transferred from the original to the replacement.
The transmission lcd flicker the electrician suspect a bad ECU but im not buying it still. This mazda has a demon in it.
Old Jan 31, 2024 | 01:32 AM
amos2727's Avatar
Hi did u fix ur problems?i just wondering i have some problems do u know how to fix this after crash car not turn on is show code u0100 . What should i do ?thanks
Old Mar 2, 2025 | 09:38 AM
Delgadof06's Avatar
Default Solution?
Did they give you a solution? The same thing happens on my 2020 Mazda CX5
WillyPickton
Mar 2, 2025 12:39 PM
JoeO
Dec 27, 2020 03:12 AM
Beevee
Feb 24, 2020 02:25 AM
Sarge2155
Jan 26, 2020 01:56 PM
Hans-NM
May 3, 2019 09:48 PM
