2016 - Windshield Washer Fluid Reservoir Replacement
Old Feb 26, 2025 | 09:31 AM
Duncan's Avatar
Default 2016 - Windshield Washer Fluid Reservoir Replacement
Good afternoon all,
I think the Washer Reservoir of my 2016 CX5 needs to be replaced (has a hole in it)
Over at https://www.mazdaswag.com/ I read that a new reservoir costs about 60 bucks. That price actually seems a bit low.
At https://repairpal.com/ I read that Windshield Washer Fluid Reservoir Replacement between $216 and $252 (60/40 percent labor/parts)
Zip I used is 60504
What do you all think ? Are those numbers realistic ?
D
Old Feb 26, 2025 | 10:14 AM
The first price of 60 is about average and accurate the labor is based on your exact locality and what the current basic hour labor rate is. If those are combine labor and parts, then based on national average shop hourly rate they would be normal there abouts?? It takes an -hour to change it out. It is also a very easy task with simple common tools
Old Feb 26, 2025 | 10:46 AM
My state currently averages about $140 an hour for automotive labor.
As Calisto states that figure would be in the "ballpark" for the labor and parts.
As he said you can do it yourself and most towns/cities always have an independent "wrench" who would charge less in labor.
This repair does not really require a "certified mechanic".
We have a local Tech school that will do it things like this for free (if you supply the part) to train their students.
But they have a long wait list.
Old Feb 26, 2025 | 10:52 AM
Check craigs list your area for a Mobil mechanic.... if you don't want to do it and don't want to pay a shop cost.
Old Feb 26, 2025 | 01:35 PM
Duncan's Avatar
Sorry, but you must have misunderstood. I am not looking for a mechanic.
Old Feb 26, 2025 | 01:36 PM
Duncan's Avatar
Thanks Callisto. So I think you mean the labor numbers are realistic ? Right ?
Old Feb 26, 2025 | 01:38 PM
Duncan's Avatar
Thanks Lobstah
Old Mar 7, 2025 | 06:51 AM
1st step it to actually confirm the reservoir itself is leaking and not the pump, or grommet or pipes.
Old Mar 15, 2025 | 05:16 AM
retread888's Avatar
Originally Posted by Duncan
Good afternoon all,
Zip I used is 60504
D
Get a good replacement or go to pick and pull and learn how to install it by removing it from a donor car - this is a great learning method for new DIYers - and it saves $$$ - this is not a hard fix - go for it
Old Mar 15, 2025 | 09:23 AM
wow! this is funny reading.... got to say done it myself in the early 1980's.
The problem is unlike before many DIY may not do well because of the new use of terms LOLFor safety and environmental reasons:
  • No torches
  • No body saws
  • No jacks
  • No batteries
  • No battery jump packs
  • No cores with oil
  • No glass containers or other glass objects
  • No alcohol
  • No smoking
  • No children under 16 years of age in the yard
  • Children in the waiting area must be under customer-provided adult supervision at all times
