View Poll Results: Any other folks have this problem?
Not sure what an option is - new member.
100.00%
Inside panel or engine compartment.
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2014 CX5 Cruise Control fuse location
Old Aug 31, 2025 | 02:39 PM
GGAILLAR's Avatar
Default 2014 CX5 Cruise Control fuse location
Control stopped working after short stay in a rest area during long trip north. I’d like to check fuse first. Panel cover in cabin has no diagram. I understand it is likely a 10 amp fuse. Anyone know where it is located or should I just pull 10 a fuses & check at random (which sounds like a plan)?
Checked both covers & diagrams stamped on covers - none list cruise control!
Old Sep 1, 2025 | 06:44 AM
Default addition
Cruise Control is normal under the ABS system.
Fuse is located under the hood fuse box #16 and is (50AMP)
Also note that a common cause for cruise control not working is a bad break pedal switch (though there are many more reasons).
2014 Mazda CX-5 fuse box diagram - StartMyCar
Old Sep 1, 2025 | 08:41 AM
Old Sep 1, 2025 | 10:14 AM
GGAILLAR's Avatar
Thank you. Hope it is a simples solution. - Jerry
Old Sep 17, 2025 | 10:14 AM
GGAILLAR's Avatar
Default 2014 CX5 cruise control
Replacing the brake pedal switch rectified the problem. I needed help as after hip replacement I was unable to contort my body under the dashboard - heater vent made access to switch bracket tough & terminal block has very little slack in wiring for the five leads.
Thanks all for helping me!
Old Sep 18, 2025 | 06:34 AM
Glad to hear you solved the problem.
At 72 after multiple motorcycle accidents and assorted surgeries I fully understand the no contortion body anymore.
I'm lucking I can still get in a vehicle...and getting out is still a challenge
Old Sep 18, 2025 | 08:24 AM
GGAILLAR's Avatar
Default 72 & motorin'
I am 78 and reeling from hip replacement in May and rehab going sour, so I share the glee of getting old!
Old Sep 18, 2025 | 12:25 PM
I suspect we'll see each other soon on a mobility scooter forum...
Old Sep 18, 2025 | 12:32 PM
You should come retire where I live... everyone seems to own a golf cart here. Restricted to state wide regulation to mandatory max speed of 35 MPH. What fun is that?? LOL
Old Sep 18, 2025 | 01:53 PM
None, I'd have to put a 244hp Lightening LS-218 eclectic motorcycle engine in a golf cart if owned it
