Bigger tires
Old Sep 25, 2024 | 10:33 PM
Ranger4140's Avatar
Default Bigger tires
I have a 24 CX 30 and want to put bigger tires on it.
CAn I recalibrate the speedometer myself or take it to the shop?
Old Sep 26, 2024 | 12:35 AM
How much of a change are you going. Generally it is only about 1 mpg @ 60mph difference and not more the 2 mph max. However as far as I am aware tonight for the 2024 not sure anyone has the ECU program access for independents to change the speedo calibration and a dealer legally can only do it if the wheels and tire sizes are offered factory.
Old Sep 26, 2024 | 01:07 AM
Ranger4140's Avatar
Was thinking 225/60R18
Old Sep 26, 2024 | 10:04 AM
There are speed calculators on the internet you should go use them and see the difference. If it is within a mile or two mpg off its easy to remember and adjust your speed. Otherwise, you are going to be charged 1 hour min labor to correct (if possible). Now if it starts getting close to 5 mph difference which I know it won't then that is altogether different and can affect more than just the speedo reading.
Keep in mind that you also change your braking distance specification, and it may not be for the positive. There is no way to calculate that only to physically test it both on dry and wet pavement level ground using an accelerometer.
Old Sep 29, 2024 | 04:24 AM
Google is your friend.
https://www.1010tires.com/Tools/Tire...ismetric=False
REngelsen
Jul 20, 2024 07:07 PM
george m44
May 5, 2023 08:03 AM
RobertG314
Aug 15, 2022 02:30 PM
apbbnbanb_07
Nov 9, 2010 09:42 AM
silverracer18
Oct 5, 2005 11:57 PM
