Vacuum and Idle isssue
Old Jan 1, 2023 | 03:48 PM
Anarchy99's Avatar
Default Vacuum and Idle isssue
Here I go once more with a vacuum issue. It's not a vacuum leak this time, from what I have seen. So today when I went to go pickup my Leer top, all of the sudden my brakes had no vacuum and under half throttle the truck was unresponsive, and was blubbering like an old v8 with a hole in the exhaust. I checked everything, changed both vacuum lines going from the brake booster to the intake, since the check valve seemed to not work, when I blew threw it. I jerry rigged a check valve to get me home. So first off does anyone know where to get a check valve and that hose? Secondly has anyone had that issue with the truck blubbering under half throttle? I do not have a choke the truck. The truck was warmed up, there was no vacuum leaks from what I saw.
Same, truck. '90 B2220 with a 32/36 Weber.
Old Jan 1, 2023 | 09:04 PM
MeB2000's Avatar
There are a couple of external jets on the 32/36 Weber carb that can become clogged with dirt. When removing them to clean them, there is a O-ring that seals the jet.....so don't lose them!
Old Jan 1, 2023 | 09:06 PM
Anarchy99's Avatar
That's pretty odd, that they'll clog within a month of running the carb. However I've seen stranger things, so thanks I'll look at that first.
Old Jan 2, 2023 | 08:26 AM
Cusser's Avatar
Brake booster hose with check valve UE3843640
The intake/engine side hose is UB3943836A. These list for under $35 each.
bmassa
May 10, 2017 11:25 PM
GTFORZA
Jan 26, 2009 12:14 AM
dkofoed
Nov 19, 2007 01:26 PM
k4lop
Nov 18, 2007 08:14 PM
slammedc230
May 15, 2007 12:06 AM
