torsion bar help
Hey, i have a 93 mazda b2200, and i want to take the sag out of the front end, so it sits up a little higher. Basically i want the truck to run as high as it can, but i got no cash to put into it right now....
just hoping someone can explain how to adjust the torsion bars?? i think i know where the bolts are (neat the middle of the frame) just want to know if i should take the wheels off to do this? or what else i should do.?
Any advice would be appreciated
Thanks.
Thanks.
I dont exactly know where they are on the 93 but i have a 87 and i tightened mine up. the bolts will be back under the cab there will be tabs that go towards the middle of the cab. the best way to tighten that is just jack the truck up so the tires are off the ground then crank them evenly till it is at the higth you want it. you shouldnt have to go all the way they have alot of adjustment.
05b2300
Mar 17, 2007 07:41 PM
