sending unit out line cracked, leaking gas! what tanks work with 2600i???
Old Apr 5, 2009 | 08:07 PM
lil' lucifer's Avatar
Default sending unit out line cracked, leaking gas! what tanks work with 2600i???
Got a problem.....I have a 1991 mazda 2600i 4x4, reg. cab long box......
My gas tank was leaking bad when it was running, so I pulled it to find out that the metal out line that's attached to the top of the fuel sending unit was cracked.
So I began to pull the sending unit out and all the little screws are stripped. But I managed to get it out but now the tank is garbage(cause where you bolt unit to is fudged)
So now I need a sending unit for the the tank and a new tank....
what tanks will work on my truck?
I heard that as long as it was injected(2200i or 2600i) it did matter if it was 2wd or 4wd, BUT I needed to find one that was a long box, regular cab......IS THIS TRUE??????
thanks for the help
tyler
Old Apr 6, 2009 | 10:59 AM
nobody know anything about this???
Old Apr 6, 2009 | 11:53 AM
mazdab2600's Avatar
the tank has to be for your model.it bolts on to the cross supports in the frame
spectra premium lists mz6c for reg/long/efi.
new tank comes with the screws and seal
as for the sending unit.dealer unit(new) or rebuild it yourself.
as i did.
drill out the old fuel line and solder in new steel line.
mlauson
Sep 14, 2015 11:28 AM
camaroman
Dec 1, 2014 01:39 PM
jbmcclint
Nov 2, 2012 09:24 PM
Camo4x4
Oct 10, 2008 10:20 AM
Joe1989
Feb 1, 2008 12:20 AM
