Running rough after replacing thermostat.
Old Dec 19, 2014 | 10:52 AM
Tjkapp's Avatar
Default Running rough after replacing thermostat.
2001 B2300, replaced thermostat and now truck is is idling really rough like its about to stall. Any ideas what the issue could be?
Old Dec 19, 2014 | 04:08 PM
hixx's Avatar
If you disconnected the battery then it has to relearn the idle. If the throttlebody is dirty then it will have to be cleaned because the PCM has set it to factory specs and there is not enough air going by the flap to hold the idle up.
Old Dec 23, 2014 | 06:37 AM
Cusser's Avatar
Make sure that you didn't dislodge a wire or something when you did this.
And of course make sure all the air is bled out of the cooling system.
Doggyx
Aug 11, 2022 08:49 PM
knelson
Jul 25, 2006 05:04 PM
93mx3
Jul 2, 2006 12:48 AM
Izzie_g
Sep 19, 2005 10:55 PM
