Mazda B2200 engine runs very rough
Old Jan 20, 2021 | 07:58 PM
daddyof1234's Avatar
Default Mazda B2200 engine runs very rough
My Mazda B2200 1991 engine started running louder & rough recently. The acceleration was very poor. I had the truck towed home. The truck will crank, but the engine runs very rough/shakes. It will barely move if I "ride" the clutch in 1st gear. I haven't checked anything yet. If I mash the accelerator hard the engine rattles inside. Does anyone have any ideas on what to check? It is an extended cab 5-speed transmission with a carburetor.
Old Jan 21, 2021 | 07:57 AM
Cusser's Avatar
Check fuel delivery to the carburetor. Maybe the filter sock inside the gas tank or the fuel filter is clogged.
Stock carb or aftermarket Weber???
Old Jan 24, 2021 | 08:04 PM
Default Mazda b2200 engine runs very rough
It is a stock carb as far as I can tell.
Old Jan 26, 2021 | 04:57 PM
Default rough running engine
How can you tell if the timing belt "jumped"?
Old Jan 27, 2021 | 09:18 AM
Cusser's Avatar
If timing belt jumps, then both the valve timing AND the ignition timing would be off. An easy way might be to check the ignition timing with a strobe timing light: if it's OK then the timing belt has not jumped.
Otherwise, most would pull off the drive belts and timing covers and rotate the engine so that the crankshaft gear is at TDC #1, but this can be done with the drive belts on, you may need a flashlight and a mirror. You can rotate the engine with a 21mm socket on the crankshaft bolt, will be easier if you pull the spark plugs first; maybe you can simply tighten the power steering belt temporarily and then use a socket on the PS pulley nut. See the woodruff key notch on the timing gear, where my red arrow points? That should point straight up at TDC #1. In my pictures, I've also painted lines at that position.
With the crankshaft gear pointing straight up, you can remove the top timing cover (several 6mm x 1.0mm bolts, one is longer) and look at the camshaft gear position. The Number "1" should be pointing straight up (painted yellow in my photo) - at the V-shaped mark - if the timing belt is correct.
Old Jan 31, 2021 | 05:56 PM
Thank you for all the information. When I get the chance I'm going to check this.
Old Jan 31, 2021 | 05:57 PM
Thanks for the info. When I get a chance I'm going to check this.
chrisc1748
Mar 10, 2018 09:09 PM
Daman
Sep 14, 2009 04:25 PM
bleach
Sep 11, 2008 11:59 PM
slammedc230
May 29, 2007 12:16 PM
