little help please???
Old Jun 7, 2007 | 05:02 PM
thedriver's Avatar
Default little help please???
hi my GF has a 1987 B2200 SE-5, i need to change the plugs, wires, and maby the distributer cap. anyway im not sure if it fuel injected or if it hs a carb. sorry for the noob q. thanks
Old Jun 7, 2007 | 09:59 PM
Cusser's Avatar
Default RE: little help please???
This likely won't help you, but my '88 B2200 SE is carbureted. And my '88 Mazda Manual only details repair info for carbureted, and Autozone.com only lists fuel injection stuff starting with '89. One way to tell is to lift off the air cleaner and take a look; if it has a mechanical fuel pump under it, then for sure it's carbureted (that should also show you whether it's got carb or not). It might be possible to have electric fuel pump in gas tank though (like for auto transmission, I think) and still be carbureted.
Old Jun 7, 2007 | 10:12 PM
backintime's Avatar
your truck is carburated.As far as the comment cusser said about the its sometimes true that the fuel pump might be either in the tank or a mecahnical pump attatched the the side of the block hitting the cam.I have a 1989 and im pretty sure its the same setup so its carburated and it has amechanical fuel pump.
backintime
Old Jun 11, 2007 | 05:24 AM
toddluck's Avatar
ok look on pass side behind the engine on the engine if there is a fuel pump there it has a carb.......nice pic cuzzer...lol
mxchick08
Jul 27, 2008 05:32 AM
tylerhundley
Aug 12, 2007 05:55 PM
mazdaman22
Jul 20, 2007 09:40 PM
javdj2fan
Jul 13, 2007 08:04 AM
krutter9900
Aug 6, 2006 02:09 AM
