leaky water pump ...help!
Old Jun 26, 2009 | 08:04 PM
mdlearnest's Avatar
Default leaky water pump ...help!
hi all, i just replaced the water pump in my sons 92 b2200 p/u 2.2. it leaks like crazy! i used rtv on both sides of the gasket. could this be my problem? the old gasket didnt have any rtv or other sealer at all. i just removed the pump (again) and cleaned off the rtv and old gasket. other than tightening to specs, should i use rtv or no? any help would be greatly appreciated.
Old Jun 28, 2009 | 09:18 AM
hixx's Avatar
It may not be the waterpump leaking. Check the freeze plug above it. I would leave the timing cover off and pressure test the cooling system to see where the leak is if it's not obvious.
iggyrex
Oct 7, 2008 07:35 AM
Leykis101
Jul 20, 2008 08:42 AM
spiderpig
Aug 12, 2007 10:47 PM
626mazdaspeed
Jun 26, 2007 07:24 PM
themazdafairy
Apr 20, 2007 10:22 PM
