Hydaulic Valve lifters
Old May 30, 2007 | 01:48 PM
jwox's Avatar
Default Hydaulic Valve lifters
I justbought a set ofhydraulic valve lifters for my '92 2600i and am confused. It said in the ad that the truck is a 12 valve motor yet the truck required only 8 lifters, which is the number I bought. Am I missing something or do I need an additional 4 lifters to replace the whole set? The problem I'm having is a lifter ticking sound going in and out while driving at slow or highway speeds. The truck has 173k on it so I just thought it was time to replace the whole set of lifters. I'm surprised how small the lifters are! I expected a bigger item than what I got. Thanks for any info!!!
John
Old May 30, 2007 | 10:17 PM
wrecks74's Avatar
Default RE: Hydaulic Valve lifters
did you change your lifters yet ? have you had the valve cover off ? once you remove the valve cover you'll be able to see if it's a 8 or 12 valve engine.
Old May 31, 2007 | 11:36 AM
jwox's Avatar
I just took the cover off and there is two valves per cylinder on the intake and one per cylinder for the exhaust which makes 12. Looks like I need to get 4 more! Grrr, delays, delays!!
rdfloyd
Apr 24, 2010 07:24 PM
jaxondes
Mar 5, 2008 09:34 PM
Sprint57
Nov 18, 2007 05:39 PM
yourpc1596
Jul 18, 2007 06:44 PM
mazdab2200
Sep 13, 2006 03:31 PM
