How to get broken guide pin out if shifter housing
Guide pin broke inside the shifter tower, took off that top cap and its broken inside. Got another pin from a 4x4 but Im stuck on how to get the broken piece out of that little plate deal. Is there somewhere I could get another plate if I can't get this pin out? I don't even know what it's called.
Post good pictures.
My "s" key sticks. |
Originally Posted by Cusser
(Post 197074)
Pot good pictures.
You mean this pin.....at the 7 o'clock position in the picture?
https://cimg2.ibsrv.net/gimg/www.maz...a4a081c321.jpg If so, you can actually remove that part of the transmission shifter housing, make a gasket, and bolt a different one on the trans that has a good pin......or remove the part of the housing to better access it in order to replace the broken pin in your housing. https://cimg7.ibsrv.net/gimg/www.maz...49430e1f2b.jpg |
