Fuel Delivery Question
Old Nov 1, 2012 | 12:39 PM
RabieShot's Avatar
Default Fuel Delivery Question
I have a 1991 Mazda B2600i that is fuel injected.
I was wondering if I could use a gastank/sending unit etc. from another mazda truck that has a throttle body
Old Nov 1, 2012 | 12:49 PM
MazdaTirol's Avatar
Do you mean carburetor? If so then probably not since the fuel injected units generally have the pump in the tank where carb engines usually use an engine mounted low pressure pump. You would have to get a fuel injected sending unit UNLESS your truck uses a frame mounted pump, then it should be almost exactly the same as the carby one.
Old Nov 1, 2012 | 01:03 PM
RabieShot's Avatar
That's what I suspected. Used parts are hard to find for this thing :/
Thank you for your response!
mmontgom
May 5, 2010 07:01 PM
fledermas
Mar 30, 2008 12:16 PM
blazer1985
Feb 6, 2008 12:34 PM
kclark987
Jan 7, 2008 08:53 AM
Terry1100
Apr 11, 2007 03:54 PM
