Front end update
Old Mar 29, 2022 | 02:39 PM
Cusser's Avatar
Default Front end update
OK, was rained out of softball this morning, so got a one day head start on this. After getting the front end on jackstands, I installed the new tensioner rod bushings first, took me 1.5 hours. I had a 27mm socket and a 27mm deep impact socket, but would've been a little easier if I'd had a 27mm combination wrench too. Really would've been WAY easier if the official Mazda service manual had better instructions: it states "Installation. Install as follows: 1. Install tension rod" and then lists the tightening torques. It states NOTHING about getting the little steel spacer into the new tensioner rod bushings, or that one can use the large front nut to "press" the front bushing over the steel spacer. And if Mazda had designed an additional 1 or 2mm of clearance for my sockets, that would've been nice !!!
Anyway, R&R of the new sway bar bushings took 5 minutes. And everything was torqued to specifications too, so now time for lunch break.
At least for the 3 tie rod ends (one already replaced in 2005) and the two ball joints, and toe adjustment: I've done those jobs before, and even though I think the front end play was really due to broken/worn tensioner bushings, it's time to replace those tie rods and ball joints even though they seem tight, but their boots are all torn, and I already have those close-out parts anyway.....
Old Mar 29, 2022 | 08:42 PM
Cusser's Avatar
Weather wasn't that bad today, and I worked in the garage. Got 85% of it done today: the tensioner bushings, the way bar bushings, and the left side outer tie rod end and both ball joints (they are the bolt-in type).
So tomorrow will be the inner and outer tie rod ends on the passenger side, and then to adjust the toe-in.
Old Mar 29, 2022 | 09:25 PM
The Lizard King's Avatar
Look at the bottom of your truck, bro!
Clean. No rust. God bless Arizona.
Old Mar 30, 2022 | 09:22 AM
Cusser's Avatar
True. Not a speck of rust on my B2200 and 1998 and 2004 Frontiers ! A trade off of living in the Arizona desert.
The old VWs have rust where their batteries cracked as mounted to the pan, should've stayed away from rocks. Ans Mrs. Cusser's 2005 Yukon had zero rust, but her replacement 2011 Yukon has a tiny bit of surface rust underneath, as it lived in Illinois.
Old Mar 30, 2022 | 06:47 PM
Cusser's Avatar
Finished up the passenger side inner and outer tie rod ends this morning. I used the tape measure method to set the toe, seems to work for me. But it's a fair amount of trial and error to get correct toe and to keep the steering wheel straight, why I make all adjustments to both sides equally.
The inner passenger tie rod end readily snapped out using the puller, never had one be that easy, must've been worn plus the torn boot. I use a tie rod puller from Autozone; same one at Harbor Freight too, fits tie rod ends and also ball joints, pitman arms, idler arms on my B2200.
The driver side tie rod end nut wouldn't unscrew all the way yesterday after the puller got it loose, couldn't even stop it from turning even with needlenose vise-grips; so I simply cut it off with the HF cut off tool I bought a couple of months ago, easy. Then changed clothes and took it for a test drive: quite an improvement !!!
Old Apr 2, 2022 | 09:37 AM
1992ED's Avatar
This is awesome. This is on my to-do list in the next few weeks.
Old Apr 2, 2022 | 01:14 PM
Cusser's Avatar
After a couple of days of driving, I decided to check my idler arm and pitman are, and both were tight/fine. But I decided that the one tie rod end that I didn't replace (was new in 2005, lifetime warranty) should be replaced. So I picked up a warranty replacement at O'Reilly yesterday; this morning I found that tie rod end (driver side, inner) was bad/loose even though its boot was still fine. So glad I got that replaced too, so all 4 tie rod ends are now new. And daughter was over this morning so she helped with alignment using a tape measure.
Will drive locally today, planning on 100 mile trip tomorrow.
Old Apr 11, 2022 | 07:54 PM
Cusser's Avatar
Update: I took the truck 100 miles up north for the summer. I adjusted the front wheel bearings - they were too loose - but I'm still getting some steering wheel/front end shake at about 60 mph. I strongly suspect my 15" wheels/tires which were given to me from a B2600i 4WD owner. These tires are old, do not even have the date code on the sides, and the two rears are pretty worn anyway. So time to get 4 new ones anyway. After that, if issue still exists, I'll likely have "my" local independent mechanic take a look at it sometime, as he's also 100 miles away !
Old Apr 23, 2022 | 07:09 PM
Cusser's Avatar
It turns out that the front tires are 5 years old, and have lifetime balance warranty. Just in case, I have 4 new ones on order with appointment Tuesday, and I looked at the front tires today, spinning and looking for a bump, but didn't see anything too bad. Anyway, since I now had free replacement ball joints for the passenger side, I decided to swap those in. Even those I somewhat ignored a few weeks ago because their boots looked OK and they were newer than those on the driver side - they were absolutely shot; no real up and down motion, but moved extremely easily. So good thing I got to those. If I don't get a chance to take it on highway before Tuesday, the tire store is 35 minutes away, and half highway/65mph; so if OK then, I just need two rear tires.
Old Apr 26, 2022 | 03:26 PM
Cusser's Avatar
Update:Mazda truck fixed ! Took truck in to tire store this morning; two front tires were both out-of-balance but had no defects, they do all this with laser/lights these days. So those rebalanced ones went onto the rear, with the two new tires on the front.
Highway 89 home seemed fine, way improved over the past few months.
There was a need to install the closeout and lifetime warranty replacement bolt-in ball joints and tie rod ends anyway, since the cost was so low. Plus I replaced tensioner and sway bar bushings, mine had the originals. I had also found that thread in the steering coupler had stripped out, so fixed that the old fashioned way of using a longer grade bolt and a nut to secure that.
So my next task is to replace the two front flexible brake lines within a month, already have those from RockAuto.
