Electrical SHUTDOWN...HELP
Old Jul 28, 2008 | 08:35 PM
Mitch McElveen's Avatar
Default Electrical SHUTDOWN...HELP
I have a 1989 Mazda B 2200 pickup w/ manual transmission. It has always ran great, however, about 3 weeks ago it started "shutting down". The engine cuts off and all electrical including radio, AC blower, etc. is lost. ( it acts as if you cut the ignition key off ) It will crank immediately back, runs a little rough for a few seconds, then runs fine until the next "shut down"'. This has occurred 3 times in the last 3 weeks. I have checked all battery connections and the alternator checks good. Any help would be GREATLY appreciated. thanks
Old Jul 28, 2008 | 08:44 PM
troy.clements's Avatar
Default RE: Electrical SHUTDOWN...HELP
might be the computer
Old Jul 28, 2008 | 08:46 PM
autozone does free diagnostics try there first before the dealer.
Old Jul 29, 2008 | 02:06 PM
Cusser's Avatar
ignition switch, electrical portion, absolutely
I had this happen on my B2200 a decade ago.
Old Jul 30, 2008 | 07:10 PM
thanks for the help, my nephew "mechanic" lol....suggest the same.. thanks again.
Old Jul 31, 2008 | 04:22 AM
It might also be corrosion on the main fuse.Do you lose the radio and clock settings when this occurs?
kingzjnky22
Sep 1, 2007 08:49 AM
afinepoint
May 11, 2007 02:14 PM
zappafan
Jan 12, 2007 11:48 PM
kingkelvin
Oct 25, 2006 02:06 PM
maz2
Aug 14, 2006 10:50 PM
