B2600 distributor markings
Old Oct 20, 2020 | 04:31 AM
Black2600's Avatar
Default B2600 distributor markings
Putting together a 93 g6 engine with a new head its cranking, has spark but not firing..maybe an ignition timing issue? as I wasnt sure about the markings on the distributor.
When the punch hole is lined up my rotor points to #4 on the dizzy cap. Is this the correct timing to set the distributor at tdc?
Thanks for any help
Old Oct 20, 2020 | 08:51 AM
Cusser's Avatar
Those should line up to #1. Of course engine rotation needs to be set for TDC #1 first.
And can't a B2600i distributor rotor be installed in three different orientations (for some strange reason) ????
Old Oct 20, 2020 | 02:12 PM
Black2600's Avatar
I thought it would of needed to be at #1 lead too at tdc cyl 1 compression stroke, tried matching it to point 1 on the rotor cap the best I could and ignoring the markings but still not firing.
When all the marking are lined up on the housing and drive gear the rotor only points to #4 and doesnt match any
markings with the other orientations 🤔 so confused 🤣
Old Apr 14, 2025 | 12:01 PM
roverjosh's Avatar
I know this Post is old enough to be in grade school now, but I am literally having the same problem.
I matched my markings (looked the same as yours) on my dizzy and reinstalled during my engine rebuild. Im now months later and ready to start but same issue. Fuel/spark but no start.
My dizzy also points to #4.
I was wondering what, if anything, you figured out?
Thanks a million.
Old Apr 15, 2025 | 04:49 PM
MeB2000's Avatar
Yo Josh! You're 180° out more than likely. Make absolutely sure that you are on the compression stroke for the #1 cylinder before you install the distributor........AND....then make sure that the rotor is installed so that it points to the 9:00 o'clock position (pointing to the #1 cylinder spark plug lead tower on the dist. cap) and you will be golden!
I responded to your other thread on the other site also!
Old Apr 15, 2025 | 05:49 PM
Charlescrown's Avatar
First thing. Is the valve timing correct? If so then as previously mentioned make sure your on TDC compression No1. Align the marks in the pic and slide the dissy into place. You can then have a look to make sure the rotor button is pionting towards No1 in the dissy cap. I usually make a small scratch line where the dissy lines with the head to make the timing a bit more accurate. If all fails you can put a timing light on and see just where No1 is firing.
johnjohn71
Aug 25, 2018 09:04 PM
brsmith49
Nov 26, 2013 10:15 AM
Ferret626
Oct 16, 2010 04:36 PM
LFD798
Mar 2, 2009 02:33 PM
frank franklin
Feb 8, 2007 09:28 PM
