b2500 2.5 diesel 2002 4x4
Old Dec 7, 2010 | 03:52 PM
kieran1141's Avatar
Default b2500 2.5 diesel 2002 4x4
need help have this crewcab since new onely 60.000 miles and few months ago started to get hard to start when engine hot, start first turn cold, changed primeing pump on fuel filter plus non-return valve on fuel line now garage wants to fit engine coolant tempeture switch and if not that they say its diesel injection pump, anyone met this problem, does not seem to have the same power as it used to have but never failed to start would just turn over 8 or 10 times when hot sometimes would take second go to start, help help help regard;kieran
Old Jun 15, 2014 | 02:39 AM
B2500 Graeme's Avatar
I've had same problem I've had a refurbished pump put on the after that I've had fuel line problems I replaces all fuel lines and filters it still dosent start is air getting into you fuel lines is the primer holding pressure
Old Jun 17, 2014 | 02:03 PM
kieran1141's Avatar
Default Mazda 4x4
Injectors were completely destroyed from getting dirty diesel in my local garage, which has been closed up for selling washed diesel, or so i am told, i have learned my lesson with cheap diesel, refurbished fuel pump was the answer, never ran better, guy who done pump could tell me where i was getting my diesel, told me the fuel is washed with a form of acid and about 2% of the acid is left in the fuel and this destroys the injectors in the pump. so 600 euro and thank you very much.
gatorichy
Jul 7, 2014 09:24 PM
autosportdevelopment
Dec 3, 2011 03:50 AM
topgun
Dec 24, 2009 08:12 PM
topgun
Mar 30, 2009 03:50 AM
willfitz
Dec 19, 2007 07:10 AM
