B2200 Carb Swap. How to?
To swap out the stock carb and install a Weber on a California car (now deep in AZ dessert ) with all the smog parts how do you blank off the smog systems.
READ this: https://www.mazdaforum.com/forum/maz...version-30671/
Make sure you click on links in posts. Not sure if it's California Emission Approved, but it's all you get! |
3 Attachment(s)
Lots of interesting info..
I have a different motor. Mine is a B2200 with a primary cat-conv. which has 3 pipes that connect to the air filter container. This is my be a problem. Pics in the morning.. |
Originally Posted by Mr_Leffe
(Post 153188)
3 Attachment(s)
Pics of the plenum with the 3 reed valves, plumbing running down to the primary cat/vert. Attachment point.
Can this all be discarded and blanked off. |
If your truck is not in Maricopa or Pima county, no emissions tests. I have this on my '88 B2200. You can plug the three rubber hoses with rubber stoppers from Ace Hardware, or just remove them, which I later did.
I made a steel block off plate and slid that in and bolted it down where the twin tubes bolt on. I use capped lug nuts ($6 pack of four) to seal off the four ports on the exhaust. |
So I can remove the whole pipe system and blank it of. Great. Any chance of pics.
Which Weber did you use? Where from? |
(Post 153254)
MazdaBScene.com ? View thread - My October 2011 B2200 Engine Rebuild http://www.cardomain.com/ride/233451...photo-gallery/ I had other photos but when Mazdatrucking.com had a crash, they were lost, would need to take new ones. Might be easier if you supply E-mail address and I could E-mail them over the weekend.
(Post 153254)
