93 B2600 Starts and immediatly stalls
Old Jan 29, 2013 | 09:51 AM
  #21
bobbyksnapon's Avatar
Default Hard to start, then shuts off
I have the same issue, with a 93 B2600 as well. Cold weather definately affects the starting. The counting trick helps on the delay to start about one in five attempts. Definately seems like the boosted start helps.
Old May 17, 2022 | 02:59 PM
  #22
89 B Double Duce's Avatar
Default Ops
Originally Posted by darv2020
Hi,
I have a 1993 Mazda B2600 with 120,000 miles. Truck runs great but in the past week when I go out to start it up in the morning it will start right up and then immediately stall. This will happen a couple times and then run fine until it sits for a while and I go to start it again. I've changed the cap & rotor just the past week, The fuel tank and pump are about 4 months old. I'm getting the feeling it runs out of fuel... Is there a check valve that keeps the fuel lines pressurized? Someone mentioned to me that the fuel cap could be faulty?
Any ideas?
Thanks
Your fuel pump relay turns your fuel pump on. But when you release the key back to the "Running" position, your oil pressure sensor takes over. If the sensor is failing, your fuel pump will shut off as soon as you release the key.
johnnyzoom
Dec 29, 2007 07:00 PM
kenyasing
Jul 29, 2007 10:03 AM
Ricktm_1
Jun 15, 2007 02:26 AM
gblvdgirl
Apr 15, 2007 09:55 PM
04maz6
Apr 30, 2006 01:08 PM
