87 B 2200 P/U Starting Issues
Does anyone have issues with their P/U after driving for a while you turn off the ignition to do chores/ pump gas/ go to store and start the truck again but it hesitates will eventually turn over & start but should not be doing this
Originally Posted by Rowdawg
(Post 187665)
https://help.summitracing.com/app/an...-vapor-lock%3F |
(Post 187665)
Explain if the starter fails to spin/crank the engine, or if the engine spins and simply does not start. Detail whether you have the stock carburetor or a Weber aftermarket one; and when you try to re-start do you simply turn the key or do you do anything to the gas pedal? |
Originally Posted by Cusser
(Post 187681)
"it hesitates will eventually turn over & start"
Probably a bad starter. Remove the starter and have it bench tested at any McAutoParts store. If it fails the bench test, buy a new one with a good, long warranty.
1. Try a jump start, or at least a real battery test under load before just buying a starter.
2. Hook up (very easy to do) a remote starter (inexpensive) to the small terminal on the starter and the battery positive and try that, to eliminate the ignition switch and some safety switches from the circuit. And make sure ALL connections are good and clean. |
