2600 4wd hub-rotor frozen
Old May 29, 2007 | 09:13 AM
2600duude's Avatar
Default 2600 4wd hub-rotor frozen
I am trying to seperate the hub from the rotor that I have removed from the drivers front wheel.
I took out the 6 bolts and have tried heat, penatrating oil and a reasonable amount of beating.
They have seperated enough for the oil to run through, about .002. Did I miss something???
All this because of a broken wheel stud
Thanks in advance.
Pat
Old May 30, 2007 | 07:13 AM
2600duude's Avatar
Default RE: 2600 4wd hub-rotor frozen
Fixed, more heat/oil and beating.
Old Jun 12, 2007 | 09:17 PM
minnie's Avatar
Hey dude... Good day to you. My friend is having a problem with his mazda wheel hub. The same with your situation with your problem.
We are asking a favor if you don't mind. Can you please post here the step by step procedure on how does it happen and how does it done?
Old Jun 13, 2007 | 06:44 AM
2600duude's Avatar
Here is how I got the rotor free from the wheel hub
Removed the hub from the truck
Placed the assembly in a vice, clamping on the rotor
Removed the 6 bolts that hold the rotor on
wire brushed the area around where the rotor is attached to the wheel hub
soaked the joint around the rotor with penatrating oil
with a propane torch, heated the area around where the 6 bolts (~5 minutes) not the hub side
put a board against the grease seal and beat on it with a hammer till it seperated.
I then needed a new grease seal and I replaced the rotor(which may have been bent by this time)
Good luck
Old Jun 18, 2007 | 11:51 PM
minnie's Avatar
thanks a lot dude! that sure is a great help with our rotor and wheel issues
byeVW
Dec 21, 2008 02:00 PM
98M3
Jan 9, 2008 02:29 PM
Joemet
Dec 13, 2007 10:16 PM
Shroney
Mar 7, 2007 12:05 AM
mazdaroach
Oct 12, 2006 04:58 AM
