1994 B3000 start up issues
Old Feb 26, 2026 | 06:42 PM
aserrano's Avatar
Question 1994 B3000 start up issues
I have a base model b3000 1994, I got a brand new battery, I have replaced the starter and the starter solenoid and it still won't even crank at all. It produces 1 single click when I go to turn it over and nothing happens at all; anybody know what the problem could be?
Old Feb 26, 2026 | 06:48 PM
Old Feb 26, 2026 | 06:49 PM
why did you change all the parts before confirming what was causing the start issue first?
Now you will have to start over.
Old Feb 26, 2026 | 06:56 PM
Charlescrown's Avatar
Simple voltage drop tests need to be done. Do you have a multimeter?
Old Feb 26, 2026 | 07:11 PM
I may have started with the ground connections as we would hope that when the battery was changed and that it was a new one and hopefully tested before it was installed and since the starter and starter solenoid was changed that sort of rules out the positive cable at the starter solenoid.
Funny thought but lest hope he checked to see if he could manually rotate the engine ???
Old Feb 26, 2026 | 07:14 PM
That's always on the cards.
Old Feb 26, 2026 | 08:40 PM
aserrano's Avatar
I'm not the most knowledgeable when it comes to engines; I bought this truck to work on it myself and learn as things go wrong as a cheap and older option. But to answer your question,I trusted a friend who looked over my truck and told me, also a guy from Triple A told me it was "absolutely the starter" turns out they were both wrong. I only spent $40 on the starter and $21 on the solenoid, the battery I can return cause I still have the receipt so I'm not too worried about losing out on $60 for some parts.
Old Feb 26, 2026 | 08:43 PM
aserrano's Avatar
Honestly I'm not too familiar with engines and bought this truck to learn on, I didn't even know what that meant until about 5 minutes ago when I looked it up after your reply. I did not manually test it... it only has 119k miles on the engine though so I didn't think it had anything too bad that was wrong with it just hoping for some simple electrical parts outside of the starter/solenoid
Old Feb 26, 2026 | 10:48 PM
Well I guess your going to do a lot of learning. I suggest you find a competent mechanic that can do some basic testing.
Old Feb 27, 2026 | 12:10 AM
Start by getting a service manual. Maybe one like Chilton, Haynes, or Clymer . A factory service manual is not written for DIY so may not be the best to get in your case?
As you are in the USA if you ever interested to find a trusted mechanic let me know will post how you can find find one in your area.
