1987 B2600 carburetor vacuum diagram
Old Jan 26, 2021 | 09:41 PM
Modmechanix's Avatar
Question 1987 B2600 carburetor vacuum diagram
Hello all!
Im new here
I have a 1987 B2600 4x4. I bought it for $300! It did not have a carburetor on it when i bought it so i have no idea how the vacuum lines hook up. Ive done alot of searching on google and tried the search bar but couldnt find a diagram for the vacuum lines still. I did test to make sure it runs tho(starting fluid down the intake and it purred like a kitten)
I have to pass smog so the weber carburetor idea is out. I found a carburetor at picknpull off a ram 50 2.6L(but the vacuum lines are not set up the same as the mazdas. The carburetor is also slightly different, but basically the same.
I found one post on here that supposedly had the diagram to the vacuum lines but the image link did not work.
Anyone have pictures of there b2600? or a good diagram? Id even pay someone on here just to take detailed photos of their vacuum lines and where they go if anyone here has the oem carb still?
Thanks!
Jason
Old Jan 27, 2021 | 12:12 AM
The Lizard King's Avatar
There should be a diagram sticker on the underside of the hood.
Oh, and **** off on your "commiefornia" BS. If you don't like it, move. You won't be missed.
Old Jan 27, 2021 | 12:55 AM
The diagram doesnt have the detail I need to know which line goes where. The PO of this truck had the bright idea of painting the entire engine and hoses and wires all gloss black so i cant use any color coding on the vacuum lines either.
One day I plan to move, not sure why you care so much about my opinion on the state I live in. Maybe you should try not being triggered by everything that you disagree with.... but i guess snowflakes will be snowflakes
Old Jan 27, 2021 | 02:33 PM
How ironic. A Californian takes passive-aggressive swipes at the state he lives in because of its politics, but when someone points out to you that all you have to do is move if you don't like living there, said Californian calls the person who points out the obvious a "snowflake."
You can't fix what you are. Enjoy your time on mazdaforum.com.
bryan26
Dec 27, 2020 11:45 AM
jamesfrantz
Feb 21, 2012 01:32 AM
GTFORZA
Jan 26, 2009 12:14 AM
Kyrasis6
Jan 12, 2007 01:31 PM
ABTireman
Jun 3, 2005 03:09 AM
