what is this part for what does it do?
Old Jan 9, 2006 | 09:04 PM
ripcbx's Avatar
Default what is this part for what does it do?
Starter would not shut off in the run position of the brand new starter and ignition switch and tumbler?
Had an electrician guy come and look at the car.He said had to be a relay.Couldn't find anything really in the manuals.He listened to each one (5) on the firewall.Took each one out and each time same problem.Then he disconnected the black thing on the firewall labelled pressure sensor (numbers on it are F-201 small #s 8601 to the right and slightly lower,then E1T11574? Problem went away,starter now shuts off after starting.Anyone have any idea what this switch does? Can't find anything in the manuals about it?
Old Jan 9, 2006 | 11:36 PM
babyhuey's Avatar
Default RE: what is this part for what does it do?
If this black box is right next to all of the relays then it is probably the atmospheric pressure sensor. Should have three wires in the connector to it Light green w/yellow stripe, Light green w/ red stripe, and Yellow. This sensor is an input the the engine computer for, well, atmospheric pressure. Do not yet see how that would be tied into the starting system yet but am still following pages. Does the problem return if the connector is plugged back in????
Old Jan 10, 2006 | 10:53 PM
ripcbx's Avatar
yes it was the atmospheric sensor has nothing to do with the starter,BH was right.Went to Mazda and talked to the mechanic (nice guy,helpful) he went through the wiring diagram (I have Mazda manual no diagrams) May have been the starter interlock relay sticking shut do to the faulty ignition switch sticking on.When I pulled the main resettable fuse I may have jarred it free allowing the starter to disengage (I HOPE SO).Hopefully I won't be posting again for a while.Glad the girl can use her car again.Thanks to everyone for help.
Old Jan 10, 2006 | 11:11 PM
babyhuey's Avatar
Glad you got it resolved finally ripcbx. I had been mapping out the power flow thru the starter circuit from ignition switch and following it to the circuit opening relay and ignition relay but could not find any way that the pressure sensor could create the problem outside of a shorted wire in a very short section of emission harness between the PCM and X-12 connector. Glad it was not that anyway. You don't have to have problem to come on and post with a hello now and again.
Old Jan 11, 2006 | 09:22 PM
ripcbx's Avatar
Bh,thanks for all your work.
tcbmpv
May 19, 2013 12:12 PM
Pochi09
Aug 3, 2010 05:11 PM
yeehaw
Sep 19, 2007 09:12 PM
flyboy367
Feb 13, 2006 11:06 AM
ripcbx
Jan 9, 2006 09:03 PM
