Weird idle 626 2001
Okay with the following info provided, what is likely causing the issue?
- Rough idle, but when turning the ac on the idle goes insane (rpm jumps from 600 to around 100 and back every few seconds)
- System too lean bank 1 error code. i.e too little fuel or too much air.
- P0421 error indicating that the warm-up catalyst efficiency below threshold.
- P1250 problem with the solenoid.
I have replace the maf and solenoid and all codes seemed to go away, except the car is still idling very rough, even more so with ac turned on , and the p0421 and system too lean codes pop up consistently
mazpro00
Jun 14, 2014 04:56 PM
