Water leak
Old Aug 24, 2007 | 06:24 PM
Ausgiga's Avatar
Default Water leak
I just recently bought 2002 Mazda 626 and there is water leak appears all the time on the passenger side.Any ideas why?
It doesn't matter if I dry it out every day, still leak appears 1-2 days after.
Old Aug 24, 2007 | 08:52 PM
sstlaure's Avatar
Default RE: Water leak
If it's water (not coolant, which is sticky) it's condensation coming off of the AC system. It's completely normal.
Old Aug 25, 2007 | 02:05 PM
Ausgiga's Avatar
I forgot to say that it appears on the carpet (passenger side)
Old Aug 25, 2007 | 03:51 PM
sstlaure's Avatar
Could be the heater core. It should be coolant not water if that's the case though.
Old Aug 27, 2007 | 01:37 PM
hixx's Avatar
Theres an A/C evaporator drain on the right side. Check to see if its unpluged and if its plugged in make sure it is draining to the outside. Leaves can get in the evap and clog the drain. Compressed air blown into the drain hose will usually unclog it.
sturdybird
Aug 3, 2024 12:31 PM
neeltampa
Jan 18, 2022 03:00 AM
Richard
May 4, 2021 08:41 PM
britbabe
Feb 20, 2007 10:23 PM
austintitus3
Dec 29, 2006 02:59 PM
