Turn Signal/Lighting Control Lever - 626
Old Oct 9, 2010 | 12:02 PM
murrame's Avatar
Default Turn Signal/Lighting Control Lever - 626
My 626 (2000) Turn Signal/lighting Control lever is hanging loose and the hi/lo beam won't work (though the turn signals still do). This won't pass inspection. Mechanic will replace with new for ~ $250.00. Can't locate a used lever. Any thoughts as to how big a deal this is; whether a DIY'er ought to be able to easily replace; the quoted price, etc.? Thanks!
Old Oct 9, 2010 | 05:09 PM
Gimme3Doors's Avatar
I found two switches on eBay motors. Do a search on the site with the string "626 turn signal switch 2000" and see if what comes up is what you need. You'll have to pull the steering wheel which will require you purchase the proper puller. Other than that it's an easy replacement.
Old Oct 12, 2010 | 06:19 AM
murrame's Avatar
I guess I need a new mechanic! I bought a new switch unit at Advanced Auto Parts for ~ $45.00. I managed to install it properly myself : -) The steering wheel does not have to be pulled for this. Three screws on bottom allow plastic sleeve to be removed. Two machine screws hold unit. Wiring is tight in there but patience will pay off!
nusz
Sep 19, 2010 11:32 AM
wyciwug
Dec 8, 2007 02:54 PM
GeorgeAtl
10
Apr 13, 2006 04:29 PM
sibtrib
Sep 13, 2005 09:14 PM
rshal
Jun 10, 2005 10:48 PM
