Starter problem??
Old Apr 26, 2006 | 12:17 AM
dave87's Avatar
Default Starter problem??
Hey its me again lol... ummm had a weird problem with my car tonight... I went to start it and it didnt start... it just clicked.. so we push started it and i turned the key a couple of times while the car was running... and i seem to be able to have started it again... i guess i'll c tommorow.. any comments ??
Old Apr 26, 2006 | 12:40 AM
bkey71's Avatar
Default RE: Starter problem??
I would think a starter is most likely if the battery is charged. I have had this in other cars myself. You will hear a single click every time you attempt to start. The solenoid is engaging but the starter motor is not working. I would also make sure there are no battery cable problems, as this can do the same thing.
Old Apr 26, 2006 | 12:59 AM
dave87's Avatar
yup was maken the same thing you where describeing but the battery wasent dead...
Old Apr 26, 2006 | 11:34 PM
dave87's Avatar
so does anyone know any tricks to get a little extra life out of ur starter ???
Old Apr 26, 2006 | 11:42 PM
bkey71's Avatar
There is no way to prolong the death of a starter. When it goes, it goes.
Old Apr 27, 2006 | 10:43 PM
dave87's Avatar
kk could the humidity effect it in any way ???
Old Apr 27, 2006 | 10:53 PM
babyhuey's Avatar
I'd have to disagree with you bkey on ways to prolong the life of a starter. #1 tip : Don't use it and it won't wear out!!!![sm=bangbang.gif]
But seriously, about the only thing that will shorten the life of a starter is extended crank time. If it takes more than 3 seconds to start the car then you will be shortening life considerably. The longer the crank time the harder it is on starter.
Old Apr 29, 2006 | 01:45 AM
bkey71's Avatar
Geez, can't believe I forgot that! This also works great for brakes too!!
Old Apr 29, 2006 | 06:37 AM
ryanjaggard's Avatar
and could you just imagine the fuel economy
Old Nov 30, 2006 | 04:48 PM
dave87's Avatar
ok so it is yet a year later and i am faced with the same problem as last time.... i turn the key and it just clicks... i havent changed the previous starter... it just started working again.... anyways i have a 93 mazda 626 but its automatic... can i get the same part from it for my manuel car ?? if so can i have a blow up diagram or some basic instructions on how to go about it?? Thxs
