Rear Sway Bar Links
Old Jun 8, 2006 | 04:45 AM
alanhay's Avatar
Default Rear Sway Bar Links
Think I posted this in the wrong section just now...so re posting here>>>>>
Any help on the following would be apprecited....the Rear Sway Bar links on my 94 Mazda 626 have snapped and need replacing.
I have the parts but am not sure of the correct procedure for replacing these parts.....can anybody give me some guidance as to what I should be doing
Thanks
Old Jun 8, 2006 | 11:20 PM
babyhuey's Avatar
Default RE: Rear Sway Bar Links
Nothing fancy about replacing them alanhay. Should take a 14mm wrench to get the retaining bolts off of the upper and lower joints and then just reinstall new ones in the same position old ones came off. Not necessary to have bar loaded or unloaded so just what ever is comfortable and accessable to you. One note of caution though. Use a wire brush to clean the threads off the old links as much as possible before taking the retaining nuts off. This will greatly aid in getting the nuts off without the ball joint portion of the link turning with the nut. If it does do this then you can still use an allen wrench to hold the ball joint stud from rotating while removing the attaching nuts.
Old Jun 9, 2006 | 04:12 AM
alanhay's Avatar
Thanks for that info....worked a treat...dead easy in fact...once again thanks for the assistance
Kevin McCutcheon
Oct 31, 2014 11:08 PM
04Mazda3Sport
Oct 25, 2008 05:02 PM
nickvw
Jan 24, 2008 05:45 PM
keninn
Oct 8, 2007 08:00 PM
alanhay
Suspension
Jun 8, 2006 04:17 AM
